Results 1 to 5 of 5
    Sr. Mechanic RATRODKING is a glorious beacon of light
    Dec 2008
    south florida
    Default what type differential lube ?
    guys,. i have a 1990 k-1500 4x4 with 5.7 v-8.
    want to add some differential lube to the front and rear.
    what weight lube should i use ? i looked in my hayes and owners manual and couldnt find anything,
    i have some 80w-90, is that ok ?
    also, want to make sure the front gets the same as the rear.
    thanks.
    leonard
    Master Mechanic CarpenterGuy is a glorious beacon of light
    Jul 2008
    Leeds, Alabama
    i think the owners manual says the front should use 80w-90 and the back gets 75w-90, but i went with 80w-90 synthetic all around the last time i changed the fluid.
    2006 Silverado Z71 - 97,000 - totaled, RIP
    2006 Silverado Z71 - 70,000 (K&N 77 Series CAI, PowerAid TBS, Magnaflow dual rear exit, 33x12.50 Mickey Thompson MTZ, Tuff Country Torsion Keys, Tuff Country Add-A-Leafs)
    I'll keep my money, guns, and freedom. You keep the Change.
    Dec 2008
    south florida
    thanks for the info..
    leonard
    Jr. Apprentice usmctribe is a glorious beacon of light
    May 2009
    Riverside
    Quote Originally Posted by CarpenterGuy View Post
    You need to be carful with the type of fluid you use. Make sure its what the oweners manual says. I know synthetic sounds better and will last long, but it may do more damage to you differential. I worked on cars at jiffy lube and learned the hard way when i didnt used the correct stuff. You can call your nearest lube center and ask them they are generally very helpful or look at your owners manual.
  5. #5
    Legend 1st Synthetics is a name known to all
    Feb 2009
    Nationwide
    You are fine using a 75(80)W-90 or a 75(80)W-110 fluid weather it is conventional or synthetic. The only way you should not use a synthetic is if there is RTV used for the sealant. Silicone is used in synthetic lubricants as an anti-foam agent and will cause a reaction with RTV. The front diff should not have RTV but the rear may.
    1988-99 models
    Do not use synthetic lubricant in axles using RTV sealant.
    Synthetic lubricant will chemically atack RTV sealant.
    American Axle has only approved the use of Synthetic
    Lubricant 75W-90 GM part no. 12378261, as follows:
    a. All 8.6 inch rear axles are compatible.
    b. All 9.5 inch rear axles built before mid-February 1998
    (RTV sealant used to seal cover pan) are not compatible
    c. All 9.5 inch rear axles built after mid-February 1998
    (equipped with cover pan & gasket) are compatible.
    d. All 10.5 inch rear axles built prior to March 3, 1999 are
    compatible if axle shafthub RTV sealer is replaced with GM
    gasket part no. 327739.
    2008 GMC Sierra 2500HD Ex. Cab, Fire Red, 6.6L Duramax LMM Equipped with UTG Rocker Pods
    AMSOIL is the only oil company that...,"Recommends 25,000 mile oil changes","Gives up to four times better wear protection","Warranties your engine against oil related failure"
    Preferred Customers Save up to 30% Click here!!!
    Executive Direct Jobber ZO# 1695636
    Scott Douglass 248-721-1002
    Order online:
    www.1st-synthetics.com
Similar Threads
  1. Intermediate Steering Shaft Lube Procedure
    By dwill3015 in forum How-to Guides
    Last Post: 02-05-2012, 05:48 AM
  2. Lube points?
    By egreg in forum General Chevy Tech Q&A
    Last Post: 10-20-2009, 09:13 AM
  3. Gear Lube Study
    By 1st Synthetics in forum 1st Synthetics
    Last Post: 04-07-2009, 12:33 AM
  4. How do you drain rear differential lube 98 Suburban?
    By phoebeisis in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 12-16-2008, 08:31 PM
  5. Another Q-Can we lube window assemblies?
    By kester in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-18-2007, 01:33 PM
