I've been using this product for several years now in nearly all of my vehicles (all of which are over 100k miles) and it seems to do very well. I've had no adverse effects from using it. But is it really necessary and does it really help protect your engine? It has the consistency of honey and is just about as sticky so I'd imagine it does stick to the engine's internal components. I was wondering if anyone has any complaints or have had problems from the use of the Lucas Oil Engine... additive... stuff.
1990 Chevy Suburban V1500 4x4 "Church Bus"
5.7L TBI
3" lift - 35" tires
WARN Manual Locking Hubs
I think you should read this: http://www.gmtruckclub.com/forum/showthread.php?t=22760
Lucas is the king of this demonstration, I see them in every auto parts store I go in.
If you need to use an additive you are using the wrong oil. Many of the top synthetics and even some conventional on the market have the proper additives at the correct levels. Pouring an additive into oil that may already have the the proper amounts is not going to do any good and not recommended. I know for a fact AMSOIL and Mobil 1 say never use additives with their oils. Hope this helps.
2008 GMC Sierra 2500HD Ex. Cab, Fire Red, 6.6L Duramax LMM Equipped with UTG Rocker Pods
AMSOIL is the only oil company that...,"Recommends 25,000 mile oil changes","Gives up to four times better wear protection","Warranties your engine against oil related failure"
Preferred Customers Save up to 30% Click here!!!
Executive Direct Jobber ZO# 1695636
Scott Douglass 248-721-1002
Order online: www.1st-synthetics.com
With this question you can usually get answers at each extreme. I use the oil stabilizer which is what I beleive you are using. They also have the synthetic stabilizer that is a lot less thick. I also use the regular stabilizer in my vehicles. 1 quart to 5 quarts castrol in the truck and 1/2 quart to 4 quarts castrol in my car. I also use the fuel treatment. This could all be snake oil but who knows and probably never will. If it works, great. If not, I wasted some money. Either way in the end I probably won't know if it helped or not.
David
2004 Silverado 2500 Crew Cab 4x4, Airraid cold air intake, Throttle body spacer, Magnaflow exhaust (true dual to 2 in 1 out muffler), 6" ProComp lift (add a leaf and 5" superlift rear block), Bilstein shocks, 35's (Cooper Disoverer ST's) and 4.10 gears, Rhino Liner, fiberglass tonneau cover, extended stainless steel brake lines, firestone airbags.
1960 Land Rover Series II 88
2002 Nissan Altima (wife's Car)
1999 Saturn SC1 (the new commuter car)
Bookmarks
