i have a 96 5.7 fresh engine but i want to be able to pull harder off the line ideas?
Put a shift kit in the transmission and check the rear gears then maybe get a blower and drop on there just for spits and giggles
Really check out a new torque converter and the rear gear ratio, talk to a shop that knows what you got and they can come up with a good combo to get the torque to the wheels.
Here is a video about horses and torque
http://www.car-videos.net/articles/h...wer_torque.asp
My trucks!
1996 GMC Suburban SLT
1997 GMC Yukon SLT
ok i will look into that what about tunning chips?
I'm not sure about the 96 I have seen them for newer ones there are some folks who know more about that than I here so I will defer to them.
My trucks!
1997 GMC Yukon SLT
I was thinking about getting a hypertech programmer three for mine 97 5.7
ya same here also with a stage 2 intake and throttle body space and chip
alot of guys on here are non to impressed with spacers, hate the whistling and say they just arent worth the money
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
i would put a bbk throttle body huge difference you can also put in roller rockers and some beefed up valve springs for a bigger boost there are a few cylinder heads you can also bolt on for a real motor wake up depends on time and money or how far you are willing to go into the motor
Torque off the line eh....
GEARS!
You can mess around with a programmer...unless you have a diesel, you aren't going to see too much of a difference in the HP/FT-LBS
TBS.....$90 bolt on part...whistles...gets annoying...it does slightly increase throttle response slightly....don't get your hopes up.
2005 Chevy Silverado Z71 in Black
6" BDS Suspension Lift | 3" BDS Body Lift |17" Rock Crawler Stellies | 35" Cooper STTs | 4.56 Yukon Gears | AirAid CAI and TBS | Flowmaster 40s | HyperPAC Programmer
2001 TJ Sahara in Sienna
3.5" RE Suspension Lift | 33x12.50 Baja MTZs | D30/44 | ROKMEN Merc Front Bumper | Warn Rockcrawler Rear w/ Carrier | Warn M8000 Winch
allright sounds like a waste of time..but i think ill look into gears and a new throttle body
Bookmarks
