Results 1 to 7 of 7
    Newbie mitchh30 is a glorious beacon of light
    May 2009
    Default 6 Liter Pinging
    I have recently purchased a 2001 K2500 Suburban with 77k miles on it. I've noticed on cold start ups that it makes a pinging sound. Almost like a stuck lifter. But it goes away quickly. I asked the previous owner, and he said he had looked into it and was told it was just something these motors do. I called a mechanic I go to, and he said the same thing, but also told me it's a carbonization on pistons. He said that it could be "decarbonized" but it would only last about 3 months. Does this all sound accurate? Is there a chemical solution?
    Thanks,
    Mitch
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    My 6.0 makes that noise. If you do a search you will see it common on 6.0s. If it were a carbon knock it would do it both hot and cold.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Master Mechanic Burden33 is a glorious beacon of light
    Mar 2009
    Goose bay, Labrador Canada
    2 Post(s)
    My 2001 2500hd does the same thing and the only other time ki ever noticed the pinging if whenm you give it gas going up hills. the dealer told me it was normal for the 6.0L to make it
    chevy ridin high
    Fabtech/Banks ram Air
    Fuel off road/ 315/70/17 duratracs
    Hyper tech / Spencershids
    15% Tint on front windows
    20% tint on back three windows
    Street Glow / extang tonneau cover
    color matched bow ties
    MBRP catback/Alpine
    Sr. Apprentice Bikeman is a glorious beacon of light
    Apr 2009
    Charlotte NC
    Found a TSB....
    #01-06-01-028A: Info - Engine Knock on Cold Start - (Mar 18, 2003)
    Subject:Engine Knock on Cold Start
    Models:1999-2002 Chevrolet and GMC C/K Pickup and Utility Models
    2002 Cadillac Escalade (2WD)
    with 4.8L, 5.3L or 6.0L Engine (VINs V, T, Z, U -- RPOs LR4, LM7, L59, LQ4)
    This bulletin is being revised to add an additional engine to the models section. Please discard Corporate Bulletin Number 01-06-01-028 (Section 06-Engine).
    Some of the above vehicles may exhibit an engine knock noise that begins in the first 19,000-24,000 km (12,000-15,000 mi) of use. The knock noise is most often noticed during initial start-up and typically disappears within the first 5-30 seconds (may last longer in extreme cold temperatures). The noise is usually more noticeable on the initial start-up when the temperature is below 10°C (50°F) and may be more pronounced on the first cold start following a long trip.
    This noise may be caused by an interaction between carbon that has formed on the piston, the piston motion and the cylinder wall. GM Powertrain Engineering, and an analysis of engines with this condition, has confirmed that the noise is not detrimental to the performance, reliability or durability of the engine. THIS NOISE DOES NOT HAVE ANY EFFECT ON THE LONGEVITY OF ANY OF THE ENGINE COMPONENTS.
    Important: At this time, attempts to repair this condition by replacing the engine assembly or pistons are not recommended.
    Please share the information found in this bulletin with customers who inquire about this condition. In the event they have additional questions or concerns, please advise your Area Service Manager.
    GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
    WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
  5. #5
    Legend Springthing has a reputation beyond repute
    Aug 2008
    East of Branson, Missouri
    1 Thread(s)
    Good find on the TSB. Thanks!
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
  6. #6
    May 2009
    Thanks, just what I was looking for. I'm sure a few of you know what buyers remorse can feel like
  7. #7
    Newbie KAPPITAN420 is a glorious beacon of light
    May 2009
    Quote Originally Posted by mitchh30 View Post
    Thanks,
    Mitch
    things you can do to get rid of a ping.
    high octang gas
    colder plugs
    and decarb the top of the motor.. gm has a special top engine cleaner they use.. it runs through your vacum..
    best trick is after you run it let it sit as long as you can...so it soaks in to all the carbon build up.
Similar Threads
  1. Excessive Pinging
    By bigbluesub in forum Performance & Fuel
    Last Post: 08-19-2010, 07:58 AM
  2. pinging
    By imrdcobra in forum General Chevy Tech Q&A
    Last Post: 03-28-2010, 02:43 PM
  3. 2.2 liter
    By 2.2roger in forum Performance & Fuel
    Last Post: 11-11-2009, 10:08 PM
  4. 2.8 liter 5 speed
    By Corv8 in forum Chevy S10 Forum (GMC Sonoma)
    Last Post: 07-12-2009, 02:38 PM
  5. 3.8 liter performance
    By dj_skidoo in forum Other GM Cars
    Last Post: 02-16-2009, 06:09 PM
