guys,
i have a 1990 chevy k-1500 4x4 with 350 5.7 v-8.
all stock, with 118,000 miles.
i purcheased it 5 months ago with 111,000 miles.
it does have an edelbrock muffler in place of the stock muffler, and i think it still has the original catalytic convertor.
since i purcheased the truck, i have done a complete tune up, plugs, wires, rotor, cap.
every time i try to start the tuck, either cold or hot, it takes about 3-5 seconds for it to fire up. like it aint getting spark or something.
once fired up, it runs really smooth, no missing at all.
do you think i need to get a new ignition module, that mounts inside the distributor cap ? how about a coil ?
so far it has not let me down, but it really bugs me every time i go to start the truck.
my 2003 s-10 starts really fast, as soon as you hit the key, and i would like my 1990 to fire up the same way.
any thoughts ?
thanks,,leonard
any ideas guys ?
thanks
you might try a coil.i think my brother had that problem with his truck and turned out to be the starter
-Dylan
2004 Silverado 4x4
4.8L
1986 K5 Blazer
8" Superlift w/39.5 super swampers
1992 GMC Jimmy "Blue Bomber"
4.3L Vortec
Might be your coil or your ignition module. I do know that oreillys can check your ignition module for you. I am having a similar problem with my 00 denali.
thanks guys... think i will try a module first, then a coil...
leonard
Is this your first TBI? They can take a few cranks, especially when cold. Does it start faster when it's warm? Also, try leaving the key "ON" for a second before cranking. It may be taking a second to build fuel pressure.
sounds simmilar to my problem
check out http://www.gmtruckclub.com/forum/showthread.php?t=23206
this could give you an idea
maybe try replacing you fuel pressure regulator
2000 silverado with a 5.3l v8, shorty headers, upgraded plugs, 10 mil wires, magnaflow high flow cats, flowmaster 80 series muffler(2 in 2 out) w/ 18 inch stainless silverline tips. i have a k&n CIA. its a 4x4 z71 offroad package. Ls model.
extended cab 160k miles, truxedo low profile bed cover, diablo sport predator tuner.
reman tranny @ 130k miles
Chris
WOW.
THANKS for that info chris.. i will keep that in mind.
hope to swap out my ignition module and coil tomorrow, and will post the results..
leonard
just swapped out the ignition coil and module under the distributor cap,and sprayed some carb cleaner into the carb/throttle body...
still does the hard start, about 3-5 seconds before firing up.
gonna get some injector cleaer and put it in when i fill up next time.
leonard
Bookmarks
