So my wife was pull on to the freeway this afternoon when the CEL came on. I took it down to AZ, borrowed their scanner came up with the above.
A couple of thing come to mind. First, I know some previous generation Suburban (and other models), up to 2002,had an issue with water seeping into the sensor and cause this code (or something to that affect). Second, we took a trip down to Tombstone this weekend and filled up at a station in the middle of no where. But I would probably expect to see both banks throw this code if was fuel quality related.
Couple of questions: a) anybody of how to test the Knock sensor? b) anybody know where it's located and/or an R&R procedure for the knock sensor?
Also, any additional information on this issue would help.
>>>2003 Suburban K1500 LT<<<
Currently:
~Rear overhead DVD
~Orion 600D
~ 12" Acoustic Elegance AV12
~Hankook ATM DynPro A/T's
~Flowmaster exhaust
All I know is that if the code ever reads circuit that there is problems in the wiring or voltage not necassarily the sensor itself
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
I had the exact same codes on my 02' Silverado. On mine to get to the sensors I had to take off the intake manifold and they was right under that. To replace them you just pop off a rubber cover and electrical connector and just unscrew them. But after I replaced mine I got the code again and it ended up being wiring. I mean the censors where pretty corroded so I'm glad I replaced them.
Problem here to my check engine light came on couple months ago had it checked # 2 knock sensor is the problem mech said don't worry about it put a piece of tape over it ? Fixed the problem he said LOL
2002 Chevy Tahoe 4X4 33's Dick Cepek's Mud Country,3" Rough Country Lift,Black Ultra's 17" wheels,Alpine/Kicker audio system,K&N Cold air intake to much more to list !
You can watch the sensor feedback with a scanner. If you tap on the manifold with a large wrench you will see the feedback voltage change if the sensor is working correctly. Make sure you have no exhaust leaks or noisy lifters because any noises including stereos can set a knock sensor code.
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
So my subs could be the reason it shows my sensor is bad ? If that is true I'm gonna get the shop to reset the computer and leave the volume down for awhile to see if this my problem !
i think there is a tsb out on knock senors for the newer models had one in the shop the other day and the acutal sensor was bad and gm had them on nation back order cause of the recent problem they haven't produced enough to to restock :P
Bookmarks
