Results 1 to 6 of 6
    Jr. Apprentice safetyfast is a glorious beacon of light
    Jun 2009
    Default Steering issues 2500 2WD
    I'm the proud new owner of a 1997 2500 ext. cab, long bed 2wd. I've been fixing lots of little things and want to improve the steering. The steering is a bit vague, like the big old 70's cars. I know that it also needs an alignment by the uneven wear on the front tires, plus the steering wheel is pointing off center to the left, but don't want to pay for an alignment before I fix any suspsension problems. I greased all the fittings, and the tie rods look okay. Will replacing the pitman arm fix the issue? IF so, how hard is replacement? Should I also attempt some adjustment on the steering column?
    Legend Z71_guy is a splendid one to behold
    Feb 2009
    Minnesota
    best thing to do is bring it to a shop and have them check out all the steering components, ie. idler, pitman, ball joints, tie rod ends, bushings and such most shops have a steering and suspension inspection we charge 40 bucks for it but it will tell you every thing you should replace before you align the vehical.
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    What I would is take it in for a free estimate at a good front end shop. Then you will know for sure which parts are worn out. Otherwise it's just hit or miss and you will have 10 different people telling you to change bushings, ball joints, tie rod ends and sway bars.
    Have fun and welcome aboard.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Jun 2009
    No offense intended, but I'm a little surprised with the advice to go to a shop. While sound, I'm in a rural area, and usually fix everything I possibly can myself.
    1997 C2500 Cheyenne
    350 V8
    4L80E / 3.73
  5. #5
    Feb 2009
    Reno, Nevada
    You mentioned it needed an alignment and if it's wearing tires it does. I just assumed you had an alignment shop near by.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
  6. #6
    Jun 2009
    Quote Originally Posted by Jimmiee View Post
    There is. Well, technically not a front end shop, but a couple of tire shops that do alignments. I just usually do the suspension work, then take my vehicles into town for alignment. Never occurred to me to get a shop to diagnose something I wasn't going to hire them to fix. I probably should have made that clearer.
    1997 C2500 Cheyenne
    350 V8
    4L80E / 3.73
Similar Threads
  1. Steering Issues
    By ahobson1 in forum General Chevy Tech Q&A
    Last Post: 07-16-2010, 08:03 AM
  2. 2009 Suburban steering issues after leveling kit
    By E ELLER in forum Chevy Truck Accessories
    Last Post: 11-30-2009, 08:45 PM
  3. 1985 Suburban steering issues
    By KLRjunkie in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 09-13-2009, 01:08 AM
  4. 04 Sierra 1500 Steering Issues
    By skooba0201 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-14-2008, 06:07 PM
  5. Steering issues
    By marge1990 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 11-28-2007, 01:46 AM
