Results 1 to 5 of 5
    Newbie RedRocket01 is a glorious beacon of light
    Jun 2009
    Question Grinding Noise when driving
    Hey all,
    I have noticed that when I begin to take off from a complete stop, I can hear a grinding sound that seems to be coming from the driver side front wheel or suspension. I am not sure if it is the wheel bearings, tie rod ends, or what. Any help would be greatly appreciated.
    Moderator
    GaryL is a glorious beacon of light
    Mar 2006
    The Colony, Tx
    What are you driving? 2wd or 4wd? Truck or suv?
    Gary
    99 K 1500 Suburban
    78 Silverado Big 10 w/factory 454
    1977 Formula
    1976 Trans Am
    1980 Honda CB900 Custom
    Jun 2009
    Sorry, I am driving a 2001 Silverado 2 wheel drive single cab. It's got the 5.3, it's a 1500. Any ideas? Ive heard this same sort of rattling grinding sound on similar trucks around the same year.
    Moderator
    Mar 2006
    The Colony, Tx
    Jack up the front end and put it on jack stands. Spin the wheel and see if you hear anything, then have someone turn the steering wheel from side to side to see if it is in the steering components. Try to wiggle the wheel side to side and up and down and look for movement in the parts.
    Are you sure the brakes aren't worn out or dragging?
    Gary
    99 K 1500 Suburban
    1977 Formula
    1976 Trans Am
  5. #5
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    Check the Ujoints as well if the needle bearings are slipping out it makes a loud grinding noise
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
Similar Threads
  1. 09 Silverado grinding/rubbing noise
    By nxconvict in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-05-2011, 12:07 PM
  2. Magical Grinding Noise And No Movie!
    By kickercompkid_99 in forum Powertrain
    Last Post: 04-20-2009, 01:02 PM
  3. cant believe it - Silverado Grinding Noise
    By 06piney in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-05-2009, 12:21 PM
  4. grinding noise in 2WD HI
    By EdPDX in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 12-18-2008, 06:15 PM
  5. grinding noise from rear of Burb
    By EBUNOYE in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-24-2007, 08:46 AM
