Results 1 to 5 of 5
    Jr. Apprentice 94cwbyup is a glorious beacon of light
    May 2009
    Lawton, MI
    Default MPG question 6" lift 35-36" tires
    I have a 94 silverado and I would like to install a 6" lift and 35" or 36" tires which almost requires 4.11 or 4.56 gear ratio i assume. what kind of MPG or is it GPM can i expect with this combination? by the way it's a stock 5.7L with a 4 speed automatic trans. and 4 wheel drive
    Legend
    silveradotrailblazer has a reputation beyond repute
    Dec 2008
    Andalusia,Alabama
    Cool MPG question 6 lift 35-36 tires
    I have 96 Suburban with Rancho six inch and BFGs 35s and get 12mpg city/15highway. It also has headers , exhaust and intake.
    Jr. Engineer
    masterfoxscout is a glorious beacon of light
    Apr 2009
    Fairbanks, AK
    Well, not the same engine or body style, but I have 9" of lift and 35s, 4.56 gears and I get about 10 in town and about 14-15 on the road. I also have a CAI, programmer, TBS, and performance exhaust.
    2005 Chevy Silverado Z71 in Black
    6" BDS Suspension Lift | 3" BDS Body Lift |17" Rock Crawler Stellies | 35" Cooper STTs | 4.56 Yukon Gears | AirAid CAI and TBS | Flowmaster 40s | HyperPAC Programmer
    2001 TJ Sahara in Sienna
    3.5" RE Suspension Lift | 33x12.50 Baja MTZs | D30/44 | ROKMEN Merc Front Bumper | Warn Rockcrawler Rear w/ Carrier | Warn M8000 Winch
    Sr. Apprentice drumm14 is a glorious beacon of light
    Feb 2009
    Van, WA
    After I did my lift I drove to the coast and back, I got 423 miles out of 21 gallons of gas.
    2004 Silverado 2500 HD 6.0L,Diablo Tuner, K&N, 9" custom suspension lift, 2" body lift 3" cowl induction hood, 37" Toyo M/T's 18" incubus wheels. Comp Cams 212/218 lsa 114, E-fan. Dual shock kit, Es bushings, moog chassis front end.
  5. #5
    Jr. Mechanic larryleeUSN is a glorious beacon of light
    Jun 2009
    Now stationed in San Diego , CA. but i live in hastings, fl
    you can get any where from 15-20 mpg. all depends on your driving style if you can keep your foot out of it when it when you can. go with the 4:56's. im in the same perdicament as you and all the info ive been told im going to go for the 4:56's. all the people well except fr drumm14 i dont know what hes got. but the suburban is going to differ alot from you bc the weight. and the air displacment. and and masterfox has a newer body stlye. with the 5.3 so its going to slightly differ as well. but your going to range from 15-20 you can get anywhere in that area with that setup. the size and weight of your rim is also going to be taken into consideration a low weight alloy rim will get better than a steel rim. a 16" rim will get better than a 20" unless the 20" weighs less.
    Lawrence LeeUnited States NavyEngineeering Another Change to my Truck.2004 2500HD Silverado with the DuramaxTo list a few mods 6" lift, 20's with 35'sRanch Hand bumpers front and rear w/ 16.5 warn winchMBRP Dual exhuast, Edge Juice with atttude....
Similar Threads
  1. 2" lift and 285/70/17 tires
    By fxracerx in forum Wheels & Tires
    Last Post: 07-12-2010, 02:35 AM
  2. 6" lift and 33" tires?????
    By DSpivey in forum Wheels & Tires
    Last Post: 06-04-2010, 12:40 AM
  3. What Will My MPG Drop with 4" Lift & 35" Tires?
    By TexAg95 in forum Wheels & Tires
    Last Post: 03-20-2010, 08:22 PM
  4. 3" Body Lift Tires
    By mab1322 in forum Wheels & Tires
    Last Post: 12-18-2009, 07:19 PM
  5. looking for some help - 35" tires with 4" lift
    By doa1976 in forum Wheels & Tires
    Last Post: 04-12-2009, 04:43 PM
