    Default 1999SuburbanLT WIPERs
    Hello all! My 1999 Suburban LT wipers used to work intermittantly and now have stopped completely.
    When the switch is turned on there is a buzzing sound but no wiper movement. I think it is the wiper control module. If you have an ideas I sure can use em. Where is the wiper control module located?
    I'm okay until the drought ends.
    May 2009
    Massachusetts
    Sounds like the wiper motor may have **** the bed, and concluding on their on/off functioning I would take a look at that first.
    Check fuses on the inside of the dash when the driver side door is open, and check the fuse compartment under the hood for any blown fuses/relays, if that doesn't do the trick try getting a motor from the junkyard and see if that works.
    Good luck.
    module is located on the motor and is usually the culprit.
    97 burb k1500
    I had the same problem with my 98 suburban and it was the wiper pulse module. It cost about $20-$30 depends where you go....
    I think there was a recall/update on the control boards - it's been awhile.
    GM replaced the one in my 98 Sierra. Try the dealer, if they're still open.
    Good luck,
    1999 Chevy K2500 Suburban 350
    Yes download recall info if applicable to your year and bring it with you. On my 95 the dealer changed the control board for free, but I had to tell him that I knew about the recall. Otherwise he was planning to charge me. Don't know if the recall extends to your year.
  1. wipers not parking right
    By vintage_car in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 11-18-2010, 10:30 PM
  2. My wipers need help...
    By bigdaddy77084 in forum General Chevy & GM Tech Questions
    Last: 04-09-2010, 08:15 AM
  3. Wipers come on by themselves
    By kongdc in forum Audio, Video & Gadget Tech
    Last: 07-15-2009, 12:11 AM
  4. wipers
    By billlp in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 01-12-2009, 09:25 AM
  5. Wipers
    By adidasboy918 in forum General Chevy & GM Tech Questions
    Last: 12-17-2008, 07:24 AM
