    Default squeaking noise when turning steering wheel to the left
    I've had my 08 2500HD CC 4x4 Duramax since last August and I hear a slight squeaky squealing noise when I cut the wheel to the left. Anyone know what this is?
    Sorry, I don't know what's causing it, but mine does the exact same thing! It seems to be only when I have the AC on. Seems weird that it does it only when turning to the left. At least I'm not the only one! Hopefully someone can help us!
    Matt
    Hallsville, TX
    2005 Silverado 1500 LS Crew Cab 5.3L 2WD
    K&N FIPK II
    Magnaflow Exhaust
    Hypertech Max Energy Programmer
    Suspension Leveling Kit
    Putco Element Window Visors
    Carriage Works Billet Grille
    TruXedo TruXport Tonneau Cover
    Have somebody sit in the truck with it running and steer to the left like you normally would, in park though. Carefully listen under the hood to see if you can pin point where the noise is coming from. Is it the steering box or tie rod end or ?
    Mike - OREGON
    2001 chevy silverado 4x4. 5.3L, 6 inch Fabtech lift, 35" Toyo MT's, 17" Weld Racing wheels, arma coating on rocker panels. No exhaust after cat. Pioneer stereo
    HMMM...
    MINE DID SAME FOR QUITE A BIT, AND I JUST REALIZED THAT THAT NOISE IS GONE....
    sorry for caps, forgot it was on.
    DON'T FIX IT IF IT AIN'T BROK. IF IT'S BROK - FIX RIGHT AWAY.
    WONNA THINGS DONE RIGHT, DO THEM YOURSELF
    2000 SILVERADO, CENTURION EDITION, 4WD, Z71, 5.3 VORTEC
    NO DUMM MODS
  1. Knocking in steering wheel when turning
    By rrod7390 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 10-08-2010, 02:50 AM
  2. Tahoe Squeaking Steering Wheel
    By ace2878 in forum General Chevy & GM Tech Questions
    Last: 01-07-2010, 04:09 PM
  3. Power Steering Whine only when turning LEFT, CONFUSED!!!!
    By Burnall4 in forum General Chevy & GM Tech Questions
    Last: 08-08-2009, 11:19 AM
  4. Steering wheel is squeaking!
    By mvoss2576 in forum General Chevy & GM Tech Questions
    Last: 07-01-2008, 10:10 AM
  5. Noise in steering column when turning
    By sasksuburban in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 03-20-2008, 09:10 PM
