Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Jr. Mechanic iPublicEnemy47 is a glorious beacon of light
    May 2009
    Ventura,CA
    Default Gas... Octane ?
    Ok Im sure this question has been proably asked more then once...
    What Grade Gasoline do you put in your truck?....
    Is it also bad if I used 91 octane then switch back to 87 octane because of the cost of fuel
    Jr. Apprentice ricodog77 is a glorious beacon of light
    Apr 2009
    California
    I run 91 when I'm towing my trailer and then switch back to 87 when I'm not going to be towing for a while. I do change the tune with my programmer depending if I'm towing or not. Haven't had or heard of a problem with that yet.
    The only problem you would have is if you tune your truck to run 91 and put 87 in it, it's probably going to knock a lot when you get on the pedal. Hope that helps.
    '05 Tahoe Z71
    Mods
    - Volant CAI - SuperChips Cortex Programmer - Airlift 1000s - Centerline Forged 17" Wheels - Sport Rack
    Next
    - Magnaflow Cat Back - Leveling Kit - New Shoes
    '81 Corvette
    -Bored and Stroked - K&N Intake - B&M Shift Kit - Straight Pipes to Dual Flowmasters
    May 2009
    Ventura,CA
    ok thanks...
    so mine isnt tuned so 87 would be fine?
    Sr. Engineer
    jerrynino is a glorious beacon of light
    Aug 2008
    Laredo, TX
    1 Post(s)
    it should be fine as long as you dont jump from one to another every fill up... or at least thats what ive heard... i ran 91 one week then the gas went up a good chunk so i went right back down to 87 lol... and im still running that 87
    2008 NBS Silverado Z85
    4.8 V8
    -8000k HIDS
    -AVS Bugflector II
    -20% tint all around
    -17x9 Moto Metal 951
    -Rough Country 2'' Leveling Kit
    -Putco Window Visors
    -Blacked out headlights (courtesy of JAKD-UP)
    -285/70/17 BF Goodrich All Terrains (minimal rubbing still)
    -Blacked out grille and both bumpers
    -Smoked taillights
    -Blue interior dome lights
    "A work in progress is something every man should have"
  5. #5
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by iPublicEnemy47 View Post
    It's OK to switch but I would run a few tanks of 91 and then see if you gain any fuel milegae. If you don't see a gain then why waste your money? If your engine is designed to run on 87 then 91 may just be a waste of money.
    Another thing to keep in mind as mentioned before is if you are running a programmer than don't use the 87 if you are programmed for 91. Your knock sensor will hear the ping long before you do and will do it's best to eliminate the knock. It does this by retarding your timing which will make your truck loose power even more.
    And be careful out there. There are many stations selling 85 which is bad for most engines.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
  6. #6
    Master Mechanic Crakums_GT is a glorious beacon of light
    Jan 2009
    Minot, ND
    Just for my little input i did try to see about getting more mpg with 92 but it didn't work. I now run 87 all the time because it wasn't worth the money for no gain.
    -Greg
    The fool learns not from the wise man, but the wise man from the fool.
    2004 Silverado 4x4 (Suzie)
    6" Fabtech Suspension Lift
    35" NITTO Terra Grapplers
    18" MB Wheels Predators
    Thrush Turbo Series Mufflers
    on true dual exhaust
    Grille by Option Racing
    1952 3600
    Finally getting torn down to the frame.
  7. #7
    Legend cascott325 is a glorious beacon of light
    Aug 2008
    Lawrenceburg, Kentucky
    some vehicles run better on different octanes, but if you are trying to save some money, then do what you have to
    2000 silverado with a 5.3l v8, shorty headers, upgraded plugs, 10 mil wires, magnaflow high flow cats, flowmaster 80 series muffler(2 in 2 out) w/ 18 inch stainless silverline tips. i have a k&n CIA. its a 4x4 z71 offroad package. Ls model.
    extended cab 160k miles, truxedo low profile bed cover, diablo sport predator tuner.
    reman tranny @ 130k miles
    Chris
  8. #8
    May 2009
    Ventura,CA
    ok so I will run 87 from now on
  9. #9
    Jr. Apprentice jester is a glorious beacon of light
    May 2009
    Utah
    I run 85 in mine and havent noticed any problems
  10. #10
    Master Mechanic adidasboy918 is a glorious beacon of light
    Aug 2008
    Yucaipa, CA
    I normally run 89 octane and put 91 when it's cheap or want that lil hp boost.
    Peter
    2007 Silverado LT Crew NNBS 5.3
    Stock 20"
    Black Powdercoated Billet Gas Door
    LineX Bedliner
    Go Rhino Dom II Bars
    Work in Progress
    1952 Chryler 2dr Windsor } Mine and Dad's
    Former Cars
    2000 civic hx Moded
    1993 Probe simi moded
    1985 Nissan 4x4 Kingcab
    So*Cal Group
Similar Threads
  1. Why would my 99 Suburban run better on 87 octane?
    By i_build in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-17-2010, 10:21 AM
  2. Programmer 87 Octane questions
    By HawaiiKid in forum Performance & Fuel
    Last Post: 04-14-2010, 05:13 AM
  3. Octane Boost vs 93 Octane
    By 97BurbanSLT in forum General Chevy Tech Q&A
    Last Post: 04-17-2009, 08:10 PM
  4. 110 octane in stock engine?
    By rackchaser71 in forum Performance & Fuel
    Last Post: 03-22-2009, 08:35 PM
  5. ForbesAutos: High-octane wagons
    By Steve in forum Automotive News
    Last Post: 05-08-2007, 02:22 PM
