GM Truck Club
Page 2 of 3 FirstFirst 123 Last Post byLast Post by
Results 11 to 20 of 29
  1. #11
    See if you can turn it by hand in 2WD mode. It should turn.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
  2. #12
    Legend cascott325's Avatar
    Aug 2008
    Lawrenceburg, Kentucky
    i would also say u- joints or bearings
    2000 silverado with a 5.3l v8, shorty headers, upgraded plugs, 10 mil wires, magnaflow high flow cats, flowmaster 80 series muffler(2 in 2 out) w/ 18 inch stainless silverline tips. i have a k&n CIA. its a 4x4 z71 offroad package. Ls model.
    extended cab 160k miles, truxedo low profile bed cover, diablo sport predator tuner.
    reman tranny @ 130k miles
    Chris
  3. #13
    Quote Originally Posted by 01chivyz71 View Post
    does the front drive shaft spin when im in 2HI?? this is my first 4x4 so im still learning.
    It's not supposed to. Didn't you say the problem goes away in 4Hi? That would rule out the front driveshaft. I suppose you could have a problem with the back half of the transfer case, also.
    What about CV shafts? In 2wd the tire turns the shaft, but in 4wd the front center section turns the shaft. I suppose it's possible that changing the torque loading could make the noise come and go.
    And of course, it could be the front center section too.
    Oh boy......
  4. #14
    Quote Originally Posted by 2COR517 View Post
    Oh boy......
    Well how about this. when the Ujoints start to go bad, besides noise, what other symptoms go along with it. same with wheel bearings, transfer case, front diff, CV shafts. the truck drives perfect. no vibrations. doesnt pull to either side. no clunking noises, or grinding noises. just a lil squeak. and annoying one at that. i should just take it to a mechanic...but my experiances in the past lead me to want to know whats wrong BEFORE i take it in. maybe i can figure out a way to attach a sound file of the noise. let me see what i can do.
  5. #15
    Could be the driveshaft center support bearing?? Just one other place to look.
  6. #16
    Very curious as I recently bought a 99 GMC Sierra Classic 1500 4x4 Ext Cab and have the same weird chirping squeeling sound. Speed varies anywhere from 20-50mph, but only does it under power, not coasting in neutral. Any slight increase or decrease in speed and it stops. No other resistance to rolling, pulling side to side or anything.
    Also noticed it really seems to start singing right around 1600-1800 rpm so I was thinking it may be a bad belt or pulley. Just replaced both the idler pulley, tensioner and pulley and belt tonight and no luck - still chirps and squeals.
    The truck only has 50k miles on it and almost totally stock so I was doubting it would be wheel bearings. But maybe? These trucks look like they have a sealed bearing assembly? Not like the old trucks where you can pull them apart and repack them. I could be wrong - that is just by glancing at a parts catalog.
    My u-joints also don't have any grease fittings but all feel tight. A little rusty maybe.
    I haven't tried 4-hi to see if I still get the chirp and squeal but that will be my next test.
    Man it is an annoying squeal though!
  7. #17
    Just tried 4-hi and same problem immediately. Did a little 4-low and 4-high back and forth in a parking lot and then the squeal seemed to die down and stop for about 5-10 min of normal driving.
    Weird; that leads me to believe the front diff or CV joints are getting dry? Or could just have been a fluke. I guess it still could be u-joints on the rear driveline. That will be by next target...
    I just hate to start replacing things left and right until it's finally solved but I don't like paying shop mechanics either!
  8. #18
    If you really want to isolate the rear driveshaft, take it out! Drive around in 4Hi for a little while.
  9. #19
    Won't I blow tranny fluid all over the place when the rear driveline is out out - there wouldn't be a seal?
  10. #20
    Yes, you would need to cap the transfer case. Duct tape might hold for a short test, or you could get a plumbing test cap at Home Depot/Lowes/hardware store. I think one for 2" PVC would be just about right.
    Let us know if you try it.
Similar Threads
  1. Squeaks and Cracks and noise
    By ippielb in forum General Chevy & GM Tech Questions
    Last: 07-24-2010, 10:07 PM
  2. Squeaks and bad idle
    By Silverstreak in forum General Chevy & GM Tech Questions
    Last: 06-19-2009, 04:03 PM
