    Exclamation Common causes of oil consumption
    Common causes of oil consumption Technical Service Bulletin by AMSOIL:
    https://www.amsoil.com/dealer/techse...onsumption.pdf
    Scott Douglass 248-721-1002
    Order online:
    www.1st-synthetics.com
    I have question... not realted to oil
    But if I change my Transmission fluid from normal to a Synthetic will mess up
    im only asking because my tranny has 115k miles and I hear that trannys that have alot of miles dont work as good if you switch to synthetic
    2000 GMC Sierra Ext. Cab 5.3L
    Quote Originally Posted by iPublicEnemy47 View Post
    That is false. You are fine to switch to synthetic. If you asked you dealer what fluid to use they may tell you to use DEX VI. DEX VI only comes in synthetic due to how low of a viscosity it is. The synthetic fluid is much better for your trans.
    Let me know if I can help you out with the fluid and filter.
    Order online:
    ok thanks I will go ask my dealer about my tranny fluid
  1. Excessive Oil Consumption
    By dbrannen in forum General Chevy & GM Tech Questions
    Last Post: 10-24-2010, 07:47 PM
  2. 07 Tahoe excessive oil consumption
    By adamant in forum GM Powertrain
    Last Post: 12-10-2009, 08:13 PM
  3. 5.3L, 6.0L, 8.1L oil consumption
    By Marcus in forum General Chevy & GM Tech Questions
    Last Post: 06-20-2009, 11:22 AM
  4. Oil consumption
    By jamesscabetjr in forum Member Introductions
    Last Post: 01-19-2009, 04:20 PM
  5. What's your fuel consumption?
    By Steve in forum Performance & Fuel
    Last Post: 09-01-2008, 08:47 AM
