GM Truck Club
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Audio Help plz
  1. #11
    Jr. Mechanic jmonte3's Avatar
    Jul 2008
    Lafayette, La
    they are 6.5 coxials...
    how would i run power to my speakers if i got another amp?
    i'm not all that audio savy, and they are already mounted in my truck doors
    Jmonte3
    07 Sierra NBS Black Crew Cab 5.3L Z71
    15% tint
    Gmc pin stripes
    Blacked out GMC Logos
    Dual Flowmaster exhaust
    Kicker Stereo System w/ Pioneer Avic-D3 Navi/Dvd
    Volant CIA
    Edge Evolution
    Poweraid TBS
    Leveling Kit
    Changed Door Handles to match shiney black paint
  2. #12
    Jr. Apprentice crazi's Avatar
    Jun 2009
    Chandler, AZ
    Get a 4 channel amp with suffiecent power, obviously power it off of the battery(you'll have to ground it). What you do is run a remote wire from back of head unit to the amp power. This just turns the amp on when you turn your head unit on. Next you'll have to run Signal wires (red and white) from the back of the unit to the amp. Next take 14ga wire and run a wire to each speaker. Running thicker gauge wire will help the power flow. Obviously look at the amp mainly on how to wire it correctly. Just a side note: You never want to up your gain to much. Mainy people do cause it louder but, long term it will blow your speakers. My friend does all my audio. Its his hobby. I just watch but its not to hard just make sure + to + and - to -.. Haha. Hopefully this has help you out. Not sure what amp you should get, try a Car audio forum.
    1998 K2500 Silverado 4x4, 5.7L 350, 6in" SuperLift on 33" BFG's, Audio: JVC Deck, Alpine 250 pushing 1 set of Alpine Type R 6.5" Components, Kicker 4x6" running off Deck, and a Brutus 1600 pushing 2 10" Kicker CVX in sealed box
  3. #13
    Jul 2008
    Lafayette, La
    thanks that helped alot
    Jmonte3
    15% tint
    Gmc pin stripes
    Volant CIA
    Edge Evolution
    Poweraid TBS
    Leveling Kit
  4. #14
    Jr. Apprentice
    Jun 2009
    Coldwater, MS
    If the amplifier is truly 1ohm stable, then your simplest option is to wire all four sub voice coils in parallel (all positive terminals connected together into one, and all negative terminals connected together into one). The only way a single sub could match or outperform a pair is with a ported box, or some other more exotic design. But since you have the two subs, there is no reason not to use both of them.
    As a couple of people mentioned, get an amp for the midrange/high speakers. No matter what the manufacturer of your radio claims, it cannot possibly have more than 12-15 watts TOTAL power. Amplifiers need switching power supplies and transistors to produce real power, both of which take up space and produce heat, so the extra real estate is necessary.
    Another limitation that the second amp will cure is being able to remove the low-frequency (bass) information from the midrange speakers. This will prevent them from becoming damaged and allow you to play the system loude.
    Hope this helps
Similar Threads
  1. Audio help!!!
    By Shorty 71 in forum Audio, Video & Gadget Tech
    Last Post: 03-12-2010, 05:29 PM
  2. audio help please
    By jerrynino in forum Audio, Video & Gadget Tech
    Last Post: 08-12-2009, 09:14 PM
  3. JLl Audio 250.1 sub amp
    By alaxrunner in forum General Classifieds
    Last Post: 07-08-2009, 09:47 PM
  4. 2009 Silverado audio system with ipod integration by JML Audio of St. Louis
    By jmlaudio in forum Audio, Video & Gadget Tech
    Last Post: 06-28-2009, 10:54 AM
  5. Audio - do it yourself or pro?
    By Steve in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-02-2007, 08:54 AM
