Results 1 to 10 of 14
Thread: S10 tire size
    Default S10 tire size
    I was wondering if anyone knows the largest tire size that could fit on a stock 2000 s10 ext. cab? I heard it was 235/75 15. If I could go larger without rubbing, and having to lift it, that would be awesome, but I'm not sure how tall I can go.
    Well I have a 2001 S-10 extended cab, and I am currently running LT215/75/R15 on the stock wheels. I have no rubbing in the front, unless you try and make a super tight U-turn and then you will get some bump steer. When I got these tires fitted at NTB, the guy told me the max you could go is 2" bigger on the overall diameter.
    Here is a picture of the back of the truck, plenty of room unloaded but in the winter I carry 350lbs. of sand in the bed for traction. I did bottom the truck out on a steep bump, and it actually dented my wheel well bad enough to be pounded out.
    Here is the front of my truck, same size as the back and there is plenty of room. I have had these BFGoodrich's on the truck for 40,000 miles and I love them enough to buy another set.
    I have a 2000 2wd S-10 Extended Cab stock suspension. I currently have 225/75/R15 tires on the stock rims. I have not had any problems with rubbing in the front and still have plenty of room in the rear to handle the 300lbs of sand in and a big fiberglass topper in the winter.
    I have heard that 235's will fit, but I think that on my 2wd they would rub in the front. The 4x4's will probably clear but I don't think the 2wd's would.
    I do know 235's fit very nicely on the older style 1989 S-10 4x4 I used to own.
    my 2 cents: I like the 225's for ground clearance and they make the truck fly on the freeway with the 3.42 rear end but I lost a bit of the low end that I had with the stock 205's on there. Planning on trying 215's in summer and 225 snow tires.
    you can go 235/70 r15 and it will only rub on hard u turns
    Quote Originally Posted by Joel22190 View Post
    235 75 15 will rub on factory wheels on the inside, but they may work with wheel spacer
    (some one said 235 70 15 will too, spacers may help that too)
    I have 235/75 15 wrangler territories on stock wheels, they rub a bit on tight turns but nothing to worry about
    Quote Originally Posted by sonomanick View Post
    The same stock rims as above?
    I am looking to upsize the tires on my 2000 2WD S10 as well and want to know what I can fit.
    Seems 225/75/15 would be safer but if I could go 235/75/15 I would like it much more.
    Are those the new Wranglers from Canadian tire?
    What do you guys think about spacers? What size spacers would solve the rubbing issue with the 235/75/15??
    Default S10 tire sizes
    I have a 94 S10 LS 4x4 with the extened cab and the sticker in the drivers door states the proper tire size is 235/75R15.
    The tires that are on it are 30/9.50/15's. The speedometer matches the GPS (Garmin 400T) at 60 mph.
    I have ordered 235/74R15 winter tires and rims so that I can get some snow traction.
    late on this discousion but on both my 96 ext 2wd and my 00 4wd, the 235x75x15 tires rubbed in bumps or sharp turns.i now ride on 235x70x15 and it runs perfect and i get the widenes i like,no mods at the suspension.on the 4wd you can easy change riding height via torsion rods but you change the spring tension at the same time,harder for more height and softer other way
  1. tire size on an 09
    By nickgiacalone in forum Wheels & Tires
    Last: 03-26-2009, 12:46 AM
  2. Tire Size
    By laurero in forum Wheels & Tires
    Last: 03-10-2009, 10:12 PM
  3. tire size and tire availability
    By Leonard in forum Wheels & Tires
    Last: 08-18-2007, 11:02 AM
  4. 1999 k1500 ls tire no lift max tire size.....
    By ultramegabob in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 02-17-2007, 11:35 PM
  5. Need help with tire size [Expired Topic]
    By Urban Suburban in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 01-28-2007, 11:19 PM
