Results 1 to 4 of 4
    Master Mechanic Crakums_GT is a glorious beacon of light
    Jan 2009
    Minot, ND
    Default Looking for a welder
    http://http://www.minotads.com/getLi...=&p=1&a=359609
    Would this be a good welder for some minor frame/front clip welding for my 1952 pickup? If no what should I look for? I don't want something expensive since I am trying to put most of my money into actual parts for my truck. Thanks
    -Greg
    The fool learns not from the wise man, but the wise man from the fool.
    2004 Silverado 4x4 (Suzie)
    6" Fabtech Suspension Lift
    35" NITTO Terra Grapplers
    18" MB Wheels Predators
    Thrush Turbo Series Mufflers
    on true dual exhaust
    Grille by Option Racing
    1952 3600
    Finally getting torn down to the frame.
    Former Member TRPLXL2 has much to be proud of
    Jan 2009
    Norwalk, Ohio
    2 Post(s)
    1 Thread(s)
    Well I tryed the link you gave, and it said that it can't find the server?
    Well how much frame welding are you doing on your truck, is it broke clear through or is it just little spots here and there. The reason I ask is because a few years ago me and dad were working on a body off 1970 Impala convertible project, and the frame had broke completely behind the rear quarter. In order to make the frame one piece again, and make sure that it didn't twist from the heat we built a jig to hold the frame in place while we welded it. My dad took steel and basically tied the frame together, it turned out really good too. With your truck the frame should be heavy enough, but just be cautious about how much heat you put on that frame it could twit a little bit on you.
    Jan 2009
    Minot, ND
    The frame is really good. I would only be using it to box the frame and install an upgraded suspension. The most I would be welding is the mounts for the new suspension and that would really be it. The frame is not rotted so that is really good. The welder is a Century 120 amp wire feed welder. model # is 83075 if that helps. Thanks.
    -Greg
    1952 3600
    Legend tbplus10 has a reputation beyond repute
    Mar 2007
    -97.0482020 N, 32.6625890 W
    1 Post(s)
    1 Thread(s)
    For frame welding you want atleast a 220, you need good weld penetration.
    I'd also recommend if you dont have much welding experience see if the local college has a welding course, it'd be worth the time and money and will probably cost less than if you were to screw-up the frame with a bad weld.
    Tim
    2011 Silverado 1500 LT
    2008 HHR LT
    1999 Tacoma SR5 TRD 4X4
    1993 Jeep Wrangler
    1991 Toyota Rock Crawler
    2009 Harley Davidson Nightrain
    2004 Harley Davidson FLHT "Bagger"
    2003 Glastron GXL Bowrider
Similar Threads
  1. Replies: 0
    Last Post: 03-30-2010, 03:00 AM
  2. Chevrolet 1986 Chevrolet Military Truck Diesel Generator Welder
    By Steve in forum Chevy Trucks For Sale eBay
    Last Post: 12-08-2009, 04:50 PM
  3. 1992 chevy welder truck ready for the pipline!
    Last Post: 11-24-2009, 02:10 PM
  4. Good Welder?
    By Crakums_GT in forum General Chevy Tech Q&A
    Last Post: 07-05-2009, 04:08 PM
