GM Truck Club
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Sr. Apprentice
    Jan 2009
    West By God Virginia!
    Quote Originally Posted by phoebeisis View Post
    Yes, there is 15W50 Mobil I- i USE IT IN MY MOTORCYCLES(it is car oil,I refuse to pay double for motorcycle oil). The 15w50 has red writing on it,I think.WalMart sells it now for about $22 five quarts.
    If your pressure is ok now- maybe it was just a wonky gauge? I would give the 15w50 a try anyway .
    I switched from the 5w30 to 10w30high mile oil.It didn't hurt my mpg and my warm idle pressure is maybe 22 psi instead of 20 psi.
    Luck
    Charlie
    my 1998 has 210,000 runs great.
    Thanks, Charlie!
    I will definitely change over to 15W50 at the next oil change. I know Chevies run with lower oil pressure, but my Mercedes diesel with 311000 miles on it runs at over 50psi even hot.
    My truck usually runs under 200 degrees unless I am going uphill with the AC on, then she might go up to 210.
    I am thinking it is a wonky gauge that is why I want to plumb in a mechanical one at least to confirm the readings. I just don't know where to put it on a OBDII Vortech engine. I usually just pull out the sender and replace it with the gauge connection on my older cars with idiot lights... I don't want to upset the ECU by taking out a needed input
    I have no convictions ... I blow with the wind, and the prevailing wind happens to be from Vichy
    The Herd:
    FoxyCleopatra '99 Chevy Suburban 159K mi
    Rudolf 86 Mercedes Benz 300SDL - 305+K mi
    Fritzie 84 BMW 528e 234k mi
    Jenny '74 Jeep CJ5 23000 mi Factory plow package
    Former GM cars:
    1957 Nomad 283 4bbl rams horns,glasspacks disc brakes White over red
    1963 Corvair Monza 102hp convertible Aqua
    1963 Catalina 2dr 421 4bbl Navy/light blue
    1967 GTO 400 HO his/hers convertible White over red
    1971 Buick GS 455 Conv Black over red
    1977 Impala 305 2bbl Red/red
    1982 Celebrity Silver /blue 2.8 six
    1988 Corsica Red/red 2.8 six
    1996 Impala SS BBB/ gray LT1
  2. #12
    Legend
    Feb 2008
    Red Wing, Minnesota, United States
    Maybe get a new t-stat it should be running around 185 all day ling, my suburban has never broke 200, even when I have been pulling something
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
  3. #13
    Sr. Apprentice
    Jan 2009
    Quote Originally Posted by vncj96 View Post
    I will swap that this weekend. I have seen the temps fluctuate from under 200 to 210, but never higher.
    Again, it could be the gauge cluster. I really need to replace it,but for $300+ I have been living with it.
    The Herd:
    Former GM cars:
  4. #14
    Not to nit pick but this is in the wrong sub-forum
    Joseph
    Airforce Veteran (7 years)
    NRA Life Member
  5. #15
    you might also check your sending unit and make sure its not damaged or leaking
Similar Threads
  1. Replies: 4
    Last Post: 09-24-2012, 12:35 PM
  2. 1995 block and Vortec Heads into 1999 Suburban?
    By parkersnine in forum General Chevy & GM Tech Questions
    Last Post: 12-18-2010, 08:37 AM
  3. 1999 chevy suburban 5.7 vortec to7.4
    By yutyut99 in forum GM Powertrain
    Last Post: 06-12-2010, 02:54 PM
  4. 5.7L Vortec Oil Pressure Sending Unit
    By Howie in forum GM Powertrain
    Last Post: 01-25-2009, 09:58 AM
  5. 95 5.7 suburban a vortec engine or??
    By Z-burb in forum GM Powertrain
    Last Post: 02-25-2008, 10:32 PM
