Results 1 to 6 of 6
    Sr. Apprentice BurtsBurb is a glorious beacon of light
    Aug 2008
    The Lowcountry
    Default Sticky gas pedal/throttle on Suburban
    When I first start my Suburban, the gas pedal is difficult to press. It won't move at all, until I use some force to "free" it. Then it's just fine for the remainder of the time I'm driving, whether it's only a few miles or a few hundred miles. But if I stop and shut the engine off, sure enough when I re-start it, it's stuck again. Any ideas on what might cause this, and how to remedy it?
    2000 K1500 Suburban
    Sr. Apprentice kaiah723 is a glorious beacon of light
    Jan 2009
    Bridgeport, CT
    try cleaning behind the throttle body plate with carb cleaner. my olds cutlass does this somtimes. i usaually just spray some lube where the throttle cable connects to the throttle body. it works for a while. the combination of the two should solve ur problem.
    2009 cobalt ss, imperial blu metallic, lsd, dejon powerhouse intake, Dejon bpv spring upgrade, Trifecta tune, clutchmasters aluminum flywheel, clutchmasters stage 1 clutch, 20% tints,
    2008 avalanche ltz, imperial blue metalic, k&n cold air intake, Gibson cat back duel exhaust
    Moderator
    GaryL is a glorious beacon of light
    Mar 2006
    The Colony, Tx
    I had that happen on an 89 Suburban and it turned out to be the throttle cable. I put a new one on and it worked fine.
    Gary
    99 K 1500 Suburban
    78 Silverado Big 10 w/factory 454
    1977 Formula
    1976 Trans Am
    1980 Honda CB900 Custom
    Legend Z71_guy is a splendid one to behold
    Feb 2009
    Minnesota
    sounds like a sticky throttle plate, get a good throttle plate cleaner and a old tooth brush and clean the plate and throttle body
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
  5. #5
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    Cleaning will be cheaper so start there, if no change then its time for a new throttle cable, they are pretty easy to change, as long as you can twist yourself up to get it on to the gas pedal
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  6. #6
    Aug 2008
    The Lowcountry
    Talking
    I started by cleaning the throttle plate yesterday, and it's noticeably better. Thanks for all the ideas.
    2000 K1500 Suburban
Similar Threads
  1. Hood won't pop & throttle getting stiff... 90 Suburban.
    By gfam in forum General Chevy Tech Q&A
    Last Post: 12-28-2009, 07:51 AM
  2. sticky or somewhat stiff throttle
    By dustin_742 in forum General Chevy Tech Q&A
    Last Post: 12-16-2009, 09:58 PM
  3. Sticky throttle????????????????
    By Lc4short in forum General Chevy Tech Q&A
    Last Post: 10-25-2009, 07:17 PM
  4. 99 silverado gas pedal sticking/throttle body dirty
    By mgod12878 in forum General Chevy Tech Q&A
    Last Post: 12-08-2008, 08:32 AM
  5. 01 Tahoe Sticky Gas Pedal
    By nascar1 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 09-15-2008, 07:15 PM
