Results 1 to 8 of 8
    Default "Service 4WD"
    Hi all,
    My 2005 suburban started giving me a "Service 4WD" message about two months after I bought it. I took it in, they told me that it is a bad sensor, and want 500 bucks to replace it. So much for my extended warranty, two months in and my only problem can't be warranty work.
    Can anyone tell me if this sensor change is something a guy with above average mechanical skills can tackle?
    Thanks!
    Sr. Apprentice 99monguse is a glorious beacon of light
    Jun 2009
    Why won't the extended warranty cover it?
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    I would not believe it's a sensor. Get it scanned an report the code stored in memory. Then and only then will you know where the problem is.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Sr. Apprentice BurtsBurb is a glorious beacon of light
    Aug 2008
    The Lowcountry
    You may want to get a second opinion. That light came on on my Suburban in 2007. I took it to an independent shop (non-dealer). They replaced the 4X4 dash switch, which took care of the problem. Cost $169.
    2000 K1500 Suburban
  5. #5
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by BurtsBurb View Post
    Exactly! It may need a switch or a sensor or it may have a bad electrical connection. The trouble code stored in memory will tell him where the problem is.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
  6. #6
    Sr. Apprentice Bikeman is a glorious beacon of light
    Apr 2009
    Charlotte NC
    check the atc fuse in the uhfb, could be open.
    I had a intermitten "service 4wd" in my 01 burb, I can't remember what dtc it was setting for the life of me but after checking the hi-lo motor and related wiring it ended up needing the atc module. Cost was around $300 I installed my self.
    Did the shop give you a diagnostic trouble code on your paperwork?
  7. #7
    Legend Springthing has a reputation beyond repute
    Aug 2008
    East of Branson, Missouri
    1 Thread(s)
    I vote for a second opinion as well. It seems the most common problems for the S4WD light is the switch box (the push button controller) or the transfer case's actuator.
    I can't answer your question directly about whether or not you would be able to do the sensor yourself though I can tell you that the above two are easily enough done by the shadetree mechanic.
    I replaced my switches myself. Under $20 and it was done.
    Good luck,
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
  8. #8
    Alright thanks, I'm going to take it to a different mech and see if the outcome is the same.
Similar Threads
  1. "Service Brake System" accompanied by SERIOUS truck freakout. PLEASE help us!
    By theclicks in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-08-2011, 01:06 AM
  2. 2000 Z71 "service 4wd" and campaign codes
    By Stan S in forum Powertrain
    Last Post: 12-15-2009, 06:42 PM
  3. 03 "Service 4 wheel drive" message
    By 03z71ls in forum Member Introductions
    Last Post: 09-26-2009, 01:09 AM
  4. 95 Chev Suburban "service engine light"
    By slidercoach in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-11-2007, 10:11 PM
  5. Warning light on Dash.."SERVICE 4WD"
    By Shambion in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 12-24-2005, 03:22 AM
