    Newbie
    May 2009
    Pleasanton, California
    Default which wires do i tap amp into?
    well i wired up my subs and tapped the signal into the stock sub wiring harness just above the stock sub since I realized there were no output ports in the back on the stock deck. But i just realized why my subs r sooo loud when my amp is all the way down: its getting power from the stock amp too.
    soooo, which wires should i tap my amp into so they dont get boosted by the stock amp? i located about 50 wires by the front left speaker where the parking brake is, but which ones do i tap into?
    pics would be much appreciated
    thanks,
    Alex
    Apr 2008
    Fort Leonard Wood, MO
    try this website it should help you out. scroll down once you click on the link and look for the make and model of your vehicle.
    http://www.modifiedlife.com/car-ster...ring-diagrams/
    Sr. Apprentice leadpan101's Avatar
    Nov 2008
    Millersville, MD
    if you are using an amp to run you subs, the power from you stock amp should be passing through you aftermarket amp. maybe you taped into wrong wire or you got them backwards (as far as + and - )
    Leadpan101 :great:
    2003 Chevrolet Silverado Z71
    1996 Honda Accord
    Newbie
    May 2009
    alright, i got it figured out.
    i talked to my local car audio guy and he told me that the way i had it hooked up (by tapping the rca cables into the stock sub signal wire in the back) the signal was getting boosted by the stock amp. so he helped me re-route the wires that are the input to the amp to the back of the head unit. he showed we a green and brown set of wires to use that were for the front left speaker and not the subwoofer. this way, the stock amp was not boosting the signal and my amp would filter out the low pass bass-hits.
  1. Need help identifying wires!
    By mda4029 in forum Audio, Video & Gadget Tech
    Last Post: 03-08-2010, 09:42 PM
  2. Wires, wires, wires....and more wires.
    By J.mesenbrink in forum Chevy C/K Truck Forum
    Last Post: 10-19-2009, 07:56 PM
  3. Plugs and Wires???
    By brtt485 in forum GM Powertrain
    Last Post: 07-15-2009, 07:05 PM
  4. Too many wires, Too little time
    By 454Caddy in forum General Chevy & GM Tech Questions
    Last Post: 06-22-2009, 11:29 PM
  5. Aftermarket Sparkplugs wires vs Chevy Sparkplug wires
    By chevy00 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-19-2005, 10:17 PM
