Can someone explain pinion gear backlash adjustments to me in simple terms and step by step approach or to a link with that information?
Background: '89 silverado Z71 at ~239,000 started having problems with differential, new pinion gear was installed. Now ~ 3,000 miles later a different mechanic says the whining noise from differential is not having the pinion gear backlash set properly.
She sings like a banshee at 75-80 mph!
What can I do to correct this?
Thank you for the help.
'89 Z-71 4x4
'83 300SD Mercedes
'94 C280 Mercedes
'87 300TD Wagon
If it ain't broke tear it apart and find out why...
Check out here they did a show where they showed that not to long ago
http://www.powerblocktv.com/site3/in...reme4x4-videos
My trucks!
1996 GMC Suburban SLT
1997 GMC Yukon SLT
You mentioned you changed the pinion gear only? If so I don't think you will be able to get the noise to quiet down. The reason is the ring gear and pinion gears are supposed to be a matched set. If you have a used ring gear and a new pinion you can set it up perfectly and it will still be noisy. That being said if you still want to try to quiet it down you must start by looking at the contact pattern. The pattern will tell you if you need to move the pinion gear or the ring gear to achieve the correct pattern. Once the pattern is close then the back lash adjustment comes into the picture. Remember the back lash can be adjusted by moving the pinion gear and or moving the ring gear. Confused? <G>
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
Thanks for the replies. Yeah I thought it was going to be a little tricky, more fun in the sun, or headlamps depending on when I get the chance to tackle this.
'89 Z-71 4x4
'83 300SD Mercedes
'94 C280 Mercedes
'87 300TD Wagon
Bookmarks
