Results 1 to 9 of 9
Thread: i need help....
    Unhappy i need help....
    i broke a tap off in one of my motor mount bolt holes in my block any suggestions on how to remove it??
    Quote Originally Posted by 02silverad0 View Post
    Take it to a machine shop, let them do it the right way........... (learned the hard way on other parts)
    Joseph
    Airforce Veteran (7 years)
    NRA Life Member
    Dec 2008
    Gettysburg, Pa.
    Default broken tap
    I hope I can describe this so it can be understood but here goes. The tap has threads for cutting and valleys for clearing away the cuttings so those "valleys" should provide a means for getting some grip. I once had success by heating a small hex key and bending it into a U shape that fit nicely into the "valley" gaps and then used an adjustable wrench to wiggle it back and forth til it worked free. Good luck.
    Quote Originally Posted by mrfixdit View Post
    Good post! blowing a sharp blast of air also helps remove any chips. Once it starts to move keep turning it back and fourth. Work it this way until it's out.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    sweet thanks for the info
    Master Mechanic daddytech's Avatar
    Mar 2008
    Portland TN
    a good screw extractor set should be able to get it out for you too . I have a pro set, and i also was bought a set of those "grabit's" the pro set you have to drill the hole first through the center of the bolt then twist your extractor bit into the hole. let it grab and then back it out slowly. The grabit works about half of the time as long as the screw isn't too small.
    Quote Originally Posted by daddytech View Post
    The problem is you cannot drill a hole in a hardened tap.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
    Legend bry2500's Avatar
    Oct 2008
    Gloucester, MA
    My father has a set of these and they have saved my life a few times too many.
    Walton tap extractor set
    Heres a link. http://www.etoolcart.com/browseprodu...-WLT18001.HTML
    BRYAN
    "IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
    02' Avalanche 2500 Onyx Black
    8.1L Vortec
    43,000 miles
