Results 1 to 4 of 4
    Sr. Apprentice sfilipe is a glorious beacon of light
    Apr 2009
    Thompson, Manitoba, Canada
    Default Headlight Change?
    I am looking at getting some projector headlights and cannot find any for the 2009 Sierra? Is there any change from the 08? They look the same but any wiring differences? There are lots out for the Silvarado, so are they any different? Sorry if this is a stupid question just gotta know though.
    Master Mechanic Darknesss23 is a name known to all
    Jun 2008
    Brookfield, Ct.
    1 Thread(s)
    i would wait a little bit.. i doubt there are any major differences but just keep an eye out as the vendors/manufacturers just may not have updated their compatibility description yet...
    2008 Chevrolet Silverado 1500 LTZ 5.3L EC/Std Bed 4x4 Flexfuel
    Full Metal Jacket Spray on Bed Liner
    Black Powder coat Diamond Plate Weatherguard Tool Box
    Corsa Performance Sport Exhaust System
    K&N Flat Panel OEM replacement Air Filter
    Bridgestone Dueler A/T Revo tires P275/55/R20
    Black Reflective pinstripe and VORTEC hood lettering
    Billet front bowtie
    Rear Bowtie Delete
    Blue strobe grille lights
    Blue strobe rear window lights
    Blue LED Mini Light bar in front Grille
    Former Member TRPLXL2 has much to be proud of
    Jan 2009
    Norwalk, Ohio
    2 Post(s)
    1 Thread(s)
    As far as the wiring part goes, you could always switch the pig tails out for one's that would match your factory one's. The halo's and LED's all have to be hard wired in anyways, they are not plug and play on any of them so that doesn't matter. Summit Racing sells the metri-pack connectors that you can use, they are the same thing GM uses in the vehicles. If you want them bad enough there are always ways, if possible could you get a picture of your headlight pigtail?
    Apr 2009
    Thanks for the help. I found a set that should fit. Finally! Only took about 2 weeks to track a set down. Will let you know how it turns out.
Similar Threads
  1. Oil Change at Texas Oil x Change
    By Steve in forum Chevy Compact Cars (Aveo & Cobalt)
    Last Post: 06-11-2010, 04:30 PM
  2. First oil change (Since I've had it)
    By beforeiforget761 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 05-19-2010, 06:04 PM
  3. Change oil soon
    By TJ smith in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-01-2010, 12:27 PM
  4. How do you change Headlight bulb?
    By Onstarnut in forum General Chevy Tech Q&A
    Last Post: 02-24-2010, 07:03 PM
  5. want to change 6 to 8 lug, can u help!!!!!!
    By bobby in forum Lifted & Offroad Suspension
    Last Post: 08-06-2007, 08:21 AM
