Thread: ABS problems
    Default ABS problems
    I have a 2005 silverado ext cab 4x4 (with only 17,000 miles) and the ABS is engaging at random. The ABS light is NOT on, nor has it ever come on. When I come to a slow stop the ABS kicks in, or when I make sharp, tight left turns it kicks in (even though i do not have my foot on the brake). It does not occur every time, it is random, so I am unsure of the cause...would appreciate any insights you may have...? Could this just been an ABS sensor, or some bigger problem?
    You probably have an issue with one of the wheel speed sensors. A bent bracket or a rock or mud can cause the sensor to send false signals to the computer. This causes the ABS to act up. There might be a code stored in memory. If so it will tell you which sensor is acting up.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    If your ABS is engaging on regular road conditions, jack the front end of your truck up and check your from wheel bearings in both sides. I the pressed bearing happened to blow out it will leak grease onto the wheel speed sensor causing the abs to kick on and off at random times when braking because the sensor has grease on it.
  1. S10 ZR2 4x4 problems
    By footballmn in forum GM Powertrain
    Last: 01-21-2010, 08:35 AM
  2. 4wd problems
    By NewfZ71 in forum GM Powertrain
    Last: 01-11-2010, 10:35 AM
  3. 4wd problems.
    By 95Chevyk1500 in forum GM Powertrain
    Last: 12-10-2009, 01:05 PM
  4. Chevy Silverado Heater problems blower problems
    By bidutch in forum GM Powertrain
    Last: 12-13-2007, 05:59 PM
  5. Got a few problems
    By 95chevyguy in forum Chevy Silverado Forum (GMC Sierra)
    Last: 04-16-2007, 12:03 PM
