Results 1 to 2 of 2
    Jr. Apprentice ACracing is a glorious beacon of light
    Jun 2009
    Default Wheel Bearing ond Rear diff Help! PLEASE!!
    I,m trying to replace my wheel bearings, but I cant get the hub off. I have a 36 mm socket, but it keeps slipping off. Do I need a special socket/tool to remove the hub nut. Also, what torque do I need to tighten it back to. Lastly, what is the torque spec for a pinion nut, I just replaced the pinion seal. All of the manuals said to torque it back to to what it was when I took it off, but the rear differential pinion nut was loose. Any help would be greatly appreciated. Thanks!!
    1998 Chevy Z71 4x4 5.7
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by ACracing View Post
    Your pinion nut needs to be tight. There's really no torque spec for the nut because when it's installed it crushes a sleeve to pre load the pinion bearings. If you are reusing the crush sleeve then I would use loc-tight on the nut and tighten it as tight as you can get it with a small breaker bar. It takes a large breaker bar or an impact to further crush the sleeve so you should be OK using a breaker bar about 16" long.
    I'm not sure why you can't getr your wheel bearing nut loose. Are you using an impact gun?
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
Similar Threads
  1. Request for Technical Assistance 2001 K3500 Rear wheel bearing
    By andrewh in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-25-2010, 06:57 PM
  2. ABS sensor or Wheel Bearing?! HELP!
    By NKL&DIME in forum Lifted & Offroad Suspension
    Last Post: 11-29-2009, 08:26 AM
  3. Cost 04 Tahoe AWD front diff bearing kit?
    By qposner in forum General Chevy Tech Q&A
    Last Post: 10-12-2009, 11:59 AM
  4. 02 trailblazer wheel bearing help!!
    By Doug run in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 04-11-2009, 04:26 PM
  5. wheel bearing?!?
    By caprice88 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 09-26-2007, 05:42 PM
