    Default 2000 GMC ABS Module
    Ok so my ABS light turns on for no apperant reason sometimes. So I looked it up online to see if this was a recall or not. Apperantly there was a recall on the truck that has something to with abs . I also found out that the ABS module on this year has some serious problems... Its estimated at $856 to fix...
    anyone got this same problem?
    Should I call the dealer and try saying its part of recall or what should I do?
    2000 GMC Sierra Ext. Cab 5.3L
    Sr. Apprentice Bikeman's Avatar
    Apr 2009
    Charlotte NC
    probably a bad wheelspeed sensor, need to check codes in the abs module to see whats setting the light.
    There where 3 recalls relating to abs on your model year truck, if you call your dealer, they should be able to look up and see if they are still open. If you pm me the last 8 digits of your vin# number I can look it up. Though that doe'nt mean that you don't have a different problem all together.
    Quote Originally Posted by Bikeman View Post
    Ditto on the wheel speed sensor. Usually when a module goes bad you get no lights. The ABS light is telling you the module is doing it's job. Get it scanned.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    ok all my vin and pm you..
  1. Module under seat?
    By 93BURB in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 03-06-2011, 11:32 AM
  2. Flasher module
    By GSPKurt in forum GM Electrical Tech
    Last: 06-27-2010, 10:57 AM
  3. light control module or keyless entry module
    By fd8215 in forum General Chevy & GM Tech Questions
    Last: 05-01-2009, 08:45 AM
  4. 96 7.4 ignition module
    By 1stlegendtx in forum General Chevy & GM Tech Questions
    Last: 03-04-2009, 12:45 PM
  5. Abs module
    By bassalive in forum Lifted & Offroad Suspension
    Last: 12-12-2008, 11:15 PM
