Results 1 to 10 of 11
    Default engine code po449
    MY 06 GMC 4.8L has this code and can not clear it. The truck seems fine...
    This code popped up when I tried to mix E85 in the tank.
    I even disconnected the neg terminal on the battery and still would not clear...
    John
    06 Red GMC 4X4 CrewCab 4.8L
    MagnaFlow Muffler
    Lubed by AMSOIL...
    Quote Originally Posted by detailjohn View Post
    This code can set if you leave the cap loose or a bad cap can do it too. Did you overfill the tank? Overfilling the tank can saturate the EVAP canister and set the code. This is a type A hard code so disconnecting the battery wont clear it. Try driving it around for a while and let it go through it's drive cycle. If it won't clear itself you may have a bad vent solenoid or canister. Remember overfilling your tank can ruin EVAP system parts.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    I learned something else valuable today, Jimmie you are full of awesome information! My dad used to yell at me about letting the truck go too empty, to the point where I would burn up fuel pumps and other components. I finally stopped doing that, but now I have a habit of over filling my truck! Thanks for the tip, I guess I am going to have to find a happy medium. I hate EVAP stuff.
    are you sure it is a flex fuel truck? im pretty sure these truck wern't e85 compatible.
    Aug 2008
    Loganville, GA
    Ummm...the 4.8 is not made to run E85. I think either the 5.3 or 5.7 is flex fuel and will run it.
    300.00 LATER replaced the stupid Evap filter solenoid.. Mechanic showed me the part and on my truck its mounted on the frame rail WHERE IT COLLECTS DIRTY AND CRAP FROM THE ROAD! Solenoid wan't working.
    GM your pushing it..... Toyota is looking better and better.
    John
    MagnaFlow Muffler
    Lubed by AMSOIL...
    Glad you found the problem. This solenoid was replaced under warranty on my truck when the previous owner had it.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
    i only had 3/36k warranty, of course 07 get 100k warranty...
    John
    MagnaFlow Muffler
    Lubed by AMSOIL...
    Sorry to beat this to death, but I've been on different forums searching to resolve my P0449 code....I've gotten all sorts of part #'s that are AC Delco, yet none of these #'s are either valid, nor are they available....what gives ???
    *Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming - "WOW, What a ride!"
    I winged it and went with AC Delco part # 214-2149, got some heater hose and a couple of clamps, put it on the truck, after the third trip, check engine light went off.....I've had people tell me that this part may not fit my truck being it is Flex Fuel, thank God it worked, got the part from Rock Auto, $27 including shipping
  1. P0147 Engine Code
    By Demick in forum General Chevy & GM Tech Questions
    Last Post: 03-09-2010, 06:37 PM
  2. service engine soon code
    By cthegney in forum General Chevy & GM Tech Questions
    Last Post: 01-15-2010, 07:41 PM
  3. P1351 check engine code
    By 2000liftdsuburban in forum General Chevy & GM Tech Questions
    Last Post: 10-26-2009, 02:58 PM
  4. Service Engine Code
    By BajaMark in forum General Chevy & GM Tech Questions
    Last Post: 07-08-2008, 12:28 AM
  5. Check engine code
    By WI_z71 in forum General Chevy & GM Tech Questions
    Last Post: 06-27-2008, 04:25 PM
