Ok so after i had the truck for ahwile i put in a new cd player it worked great then all of a sudden my speed omiter lights and all that stuff went out along with my other dash board lights including air/light contol. i took back out the after market cd player and put back in the stock one. now the stock cd player lights will not stay on with the key turned all the way on. the lights will be on wen the key is not all the way on but when it is they will shut off. now i have that problem including the dash light promble. lol then one day my driver side window would not roll up unless the truck was all the way started. now it wont even with the truck started. i have alot of promblems :( and i want them fixed!!
PLEASE HELP
thanks
mm
2003 GMC Sonoma ZR2
bumpity bump
2003 GMC Sonoma ZR2
did you buy the connector to hook it in or did you hack the wires?
didnt the radio dim with the dash lights?
no a bought the wiring harness and no the lights didnt dim with the dash lights the dash lights just shut off completely
2003 GMC Sonoma ZR2
ya you bought a harness?
what i mean is the dash light dimmer dimmed the radio too right?
it could be just your dimmer switch going out also if you cut any wires double check to see if there frayed or loose
ya
sometings cut frayed or on the way out!
i glad you atleast bought the harness
alot people dont do that and sizzle sizzle
well i ve cheked all wires and all are good i kinda think that the roll down switch might be out
2003 GMC Sonoma ZR2
ok the window problem is fixed but still have the dash light promblem :( please help!
2003 GMC Sonoma ZR2
**cough**bump**![]()
2003 GMC Sonoma ZR2
Bookmarks
