    Default Squeaky Driver Seat
    I'm having a problem of the back rest of my driver seat squeaking on me. I've had the dealer fix this problem before and all I know is that they tightened something up on it. Any idea what it was they tightened up?
    Jake
    2006 Silverado 5.3L Flex Fuel
    Magnaflow Exhaust
    AFE Stage 2 Intake
    Quadzilla Stealth 2 Race Tune
    Legend 2ToNe04's Avatar
    Apr 2009
    Fresno California
    Maybe the bolts that are in the brackets?
    2004 4.8| Custom Paint| Tint| De-badged| Shaved Tailgate| Rollpan| Smoked Tails| Color Matched| Lowered 5/8| Suede Interior| Color Matched Interior| Indash & TVs| Mids-Lows & 2 12" CVRs| 500 & 1100 Interfires| Soundeadener| Outlaw CAI| Magnaflow|
    Future Mods: 6.0 LQ4/9| Bags|
    If you remove your sill plate and manual levers (if you have any) you can take off the seat trim panel. The only bolts that would squeak will be behind there.
    I would make sure it is actually your seat though. I had a squeak that sounded like it was behind my driver seat. It turned out to be the cab safety strap. This is a strap resembling a very thick and short tailgate cable running from your cab to your frame. The metal loop squeaks against the bolt as the plastic bushing is only installed between the loop and the frame.
    IF this is the case, you will know because you can pull the strap by hand and hear the squeak. GM put a bulleting out instructing dealers to install a plastic washer between the rubbing parts if a customer had this issue. You can fix it yourself.
    JUST A WARNING - If you try to unbolt the strap yourself, be careful. The bolt may be as seized as mine... The ratchet slipped and i cut a chunk of skin out of my finger on the sharp metal of the rocker.
    Hope this helps.
  1. driver seat problem
    By enjun in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-25-2013, 08:36 AM
  2. Sierra Denali Driver Seat
    By Vanplor.Crucible in forum Chevy Truck Accessories
    Last Post: 02-21-2011, 08:53 AM
  3. Broken Driver Seat
    By zachh1020 in forum General Chevy & GM Tech Questions
    Last Post: 07-23-2010, 02:00 PM
  4. driver side seat
    By bassalive in forum General Chevy & GM Tech Questions
    Last Post: 09-01-2009, 07:31 AM
  5. Driver's Seat - Chevy Corvette - Vette Magazine
    By Steve in forum Chevy Corvette Forum
    Last Post: 04-30-2008, 01:00 PM
