Results 1 to 10 of 17
    Default keep losing voltage
    my 03 silverado keeps dying and i put in a new battery and tested the alternator. not sure what else to look for, my battery gauge keeps going up and down and the truck idles weird. it gets really bad with the a/c on. not sure if this is a common problem but could really use some help.
    Master Mechanic
    Apr 2009
    Owens Cross Roads, Alabama
    if its a new battery id try a new alternator anyway..sombody else might be able to help you a little better though
    -Dylan
    2004 Silverado 4x4
    4.8L
    1986 K5 Blazer
    8" Superlift w/39.5 super swampers
    1992 GMC Jimmy "Blue Bomber"
    4.3L Vortec
    I would start by making sure your connections are clean. Battery, alternator, the big grounds. If that doesn't fix it, sounds like a bad alternator to me. Is it better when the truck is cold? Then get worse as the engine warms up?
    Aug 2008
    East of Branson, Missouri
    ^^ What he said x2 ^^
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
    i guess u could say that it's worse when it warms up. if i have the a/c off i can drive for a few minutes before it cuts off. it starts right back up and will go a little farther then cut off again. when i just crank it up and turn on the a/c it just idles up and down and almost cuts off. i thought it might be the alternator cuz sometimes when they test ok they can still be bad.
    Your alternator won't cause your truck to die unless the battery is dead. Does the problem happen after the battery is charged?
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    it died with a new battery. i just tried an alternator and it still idled wierd. does anybody else have a suggestion?
    Ground connections is where I would start.
    Scott Douglass 248-721-1002
    Order online:
    www.1st-synthetics.com
    X2 on ground connections. Has anyone worked on the truck before this problem happened? If so that's where I would be looking. Engine repair, alarm, stereo, accessories? Any of these repairs done lately? If so that's where you will find your problem.
    You never mentioned if you checked for codes. On today's vehicles this is the very first step on ANY kind of an electrical or mechanical problem.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
    no codes. i'm about to go back out and work on it. i've never had it worked on. this is the first problem i've ever had. i'll keep u guys updated.
  1. losing power
    By pryormancan in forum Member Introductions
    Last Post: 07-05-2010, 03:03 PM
  2. Losing power
    By aggie99 in forum GM Powertrain
    Last Post: 09-24-2009, 01:02 PM
  3. 98 K-1500 losing antifreeze
    By CharlieP in forum Chevy C/K Truck Forum
    Last Post: 05-24-2009, 10:00 PM
  4. key doesn't work i'm losing my mind
    By bassalive in forum General Chevy & GM Tech Questions
    Last Post: 11-26-2008, 07:05 PM
  5. Ford's losing $$$$
    By ChevyLover in forum The Coffee Shop ~ Chit Chat
    Last Post: 04-28-2006, 09:01 AM
