    Default Clutch fan to electric?
    does anyone know of any retailers selling a electric fan kit for a 2004 silverado. i'm looking to grab a couple extra horses for cheap. also are there any vehicles that are similar enough and come with a stock electric fan that i could go through a wrecker for cheaper? in case you havent guessed...i'm cheap lol
    Sr. Engineer
    Jun 2009
    San Diego, CA
    If you have the larger radiator, you can use the 05+ GM e-fans. If you have the smaller radiator, you can use the LS1 fans.
    Black Bear Performance- Custom Tuning Solutions
    Authorized EFILive and MAGNACHARGER seller
    What do you mean by large or small? depth? width? height? if it helps its a 1500 4x4
    You can also use one from a ford taurus that had the 3.8, search the write up section, I do believe did a write up for it otherwise search the entire forum on the search tab, I know for sure that taurus e-fan has been brought up numerous times.
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    Scott
    ΜΟΛΩΝ ΛΑΒΕ
    '94 Chevy Suburban K1500
    3" exhaust w/ aero turbine non-baffled muffler
    CFM Technologies TB spacer
    CB w/ 44" whip antenna
    Sr. Engineer
    Jun 2009
    San Diego, CA
    Quote Originally Posted by Tiny1987 View Post
    If you measure between the top bolts of the radiator, and it is 38" wide, then you have the larger radiator.
    www.summitracing.com has em by make and model it makes a nice addition to the truck then your not havin to take off the fan and clutch when your doin front of the motor stuff
  1. clutch job
    By bucklti in forum GM Powertrain
    Last Post: 03-05-2010, 08:42 PM
  2. How do I know if my fan clutch is bad?
    By OldPitPony in forum General Chevy & GM Tech Questions
    Last Post: 09-27-2009, 10:17 PM
  3. AC clutch tutorial?
    By i82much in forum General Chevy & GM Tech Questions
    Last Post: 08-21-2009, 05:58 PM
  4. clutch problems!!!
    By throwfar150 in forum General Chevy & GM Tech Questions
    Last Post: 07-23-2008, 05:34 PM
  5. Fan Clutch help
    By Dr_Zero in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-30-2007, 08:18 AM
