Results 1 to 5 of 5
    Former Member jason0595 is a glorious beacon of light
    Jul 2009
    Thumbs up Auto Diagnostic Tools Autoboss A2600 Scanner
    Hi ,have brand new Auto Diagnostic Tools Autoboss A2600 Scanner for sale.
    Here is full inforamtion.
    Net Weight : 14 KG
    Introduction:
    * Retrieve DTCs
    * Clear DTCs
    * Read current data
    * Perform component actuation tests
    * Perform system verification tests including LDP monitors, EGR, EVAP purge vapors, etc.
    * Perform special functions including Set Sync Signal, Transmission Quick Learn, ABS brake bleed, etc.
    Ford, Lincoln and Mercury
    Covers all Ford, Lincoln and Mercury vehicle systems from 1996 to 2005. Allows the Scanner to retrieve information from vehicle control units (ECUs) of engine, transmissions, auti-lock brake systems, air bags, suspensions, climate control and much more.
    Functions include:
    * Retrieve Diagnostic Trouble Codes (DTCs)
    * Erase DTCs
    * Perform Key-On Engine-OFF (KOEO) Self Test
    * Perform Key-On Engine-Running (KOER) Self Test
    * Retrieve data stream
    GENERAL MOTORS (Buick, Cadillac, Chervolet, GMC, Oldsmobile, Pontiac and Saturn)Covers vehicle systems from 1996 to 2005. Retrieve information from vehicle control units (ECUs) of engine, transmissions, auti-lock brake systems and supplemental Restraint System (SRS). Functions
    Include:
    * Erase DTCs
    * Perform module special output tests
    European
    Audi/ Volkswagen
    Covers all Audi Volkswagen vehicle systems from 1990 to 2006. Retrieve information from vehicle electronic control units (ECUs) of engine, automatic ostic Trouble Codes (DTCs) transmissions, anti-lock brake systems, air bags, instrument cluster, climate control, and much more. Functions include:
    * Erase DTCs
    * Retrieve measuring blocks (data stream) in both digital and
    graphical forms
    * Perform Basic Settings
    * Perform Adaptation
    * Perform ECU coding
    * Perform output tests
    * Reset readiness
    Mercedes-Benz
    Covers Mercedes-Benz vehicles from 1990 to 2005 using Mercedes-Benz diagnostic software and Mercedes-Benz diagnostic connectors.
    Retrieve diagnostic information on the following systems:
    * Motor Electronics (ME)- SFI
    * Hot-film engine management (HFM)
    * Motor Electronics 2.8 (ME-SF1 2.8)
    * Motor Electronics 2 (ME2-SFI)
    * Transmission
    * Electronic Selector Module (ESM)
    * Transfer Case (VG)
    * Distronic (DTR)
    * Anti-lock Brakes (ABS)
    * Electronic Stability Program (ESP)
    * Brake Assist System (BAS)
    * Sensotronic Brake Control (SBC)>br> * Suspension (AIRMatic)
    * Active Body Control (ABS)
    * Tire Pressure Monitor (TPC)
    * Air Bag
    * Left Front Reversible Emergency Tensioning Retractor
    * Central Gateway (CGW)
    * Parktronic System (PTS)
    * Overhead Control Panel (OCP)
    * Electronic Ignition Switch (EIS)
    * Keyless Go (KG)
    * Pnematic System Equipment (PSE)
    * Signal Acquisition Module (SAM-F, SAM-FR, SAM-FL, REAR SAM, Pass-side SAM, Dr-side SAM)
    * Lower Control Panel (LCP)
    * Upper Control Panel (UCP)
    * Headlamp Range Adjustment (HRA, HRA-FL, HRA-FR)
    * Battery Control Module (BCM)
    * All Activity Module (AAM)
    * Drive Authorization System (DAS)
    * Extended Activity Module (EAM)
    * System Diagnosis
    * Trailer Recognition (AHE)
    * Special Vehicle Multi-function Control Module (SVMCM)
    * Instrument Cluster (ICM)
    * Steering Column Module (SCM)
    * COMMAND/ AUDIO (D2B)
    * CD Changer (CDC)
    * Voice Control System (VCS)
    * Active Service System Plus (ASSYST PLUS)
    * Audio Gateway (AGW)
    * Hands Free System (HFS)
    * Cellular Telephone (CTEL)
    * E-call or Cellular telephone (TELE AID)
    * Dynamic Navigation (DN)
    * TV Tuner (TV)
    * Door Control Module (DCM)
    * Electric Seat Adjustement (ESA)
    * Multicontour Backcrest (OSB)
    * Seat Heater (HS)
    * Dynamic Seat (DS)
    * Automatic Temperature Control (TAC)
    * Automatic Air Conditioning (AAC)
    * Stationary Heater with Remote Control (STH)
    * Convenience Automatic Air Conditioning (C-AAC)
    * Heated Steering Wheel (HSW)
    * Rear Air Conditioning (REAR AC)
    BMW
    Covers all BMW and Mini-Cooper vehicles from 1988 to 2007 using main unit and the BMW/Mini-Cooper diagnostic software. Retrieves information on the following systems:
    * Engine (DME,DDE) Transmission (EGS)
    * Anti-lock brake (ABS)
    * Air Bag (MRS/SRS)
    * AC/Heater (IHKA/IHKR)
    * Instrument Cluster (INSTR/KOM/IKE/IKI)
    * Electronic Throttle (EML)
    * Seat Memory (SMF/SM/SLM)
    * Electronic Immobilizer (EWS)
    * Central body electronics (ZKE)
    * Cruise Control (GR)
    * Park distance control (PDC)
    * Switching center, center console (SZM)
    * Light Switching module (LSZ/LCM)
    * Steering-angle sensor (LEW/LWS)
    * Radio (RAD/RCC)
    * Signal-axle air suspension
    * On-board monitor (BM/MIR)
    * Automatic Interval Control (AIC)
    * Navigation System (NAV)
    * Multi-function steering wheel (MFL)
    * Language-input system (SES)
    * Car Access System (CAS)
    * Dynamic Drive (ARS)
    * Chassis Integration Module (CIM)
    * Dynamic Stability Control (DSC/ASC)
    * Electronic Ride-level Control (EHC/EHC2)
    * Parking Brake (EMF)
    * Amplifier (AMF)
    * Audio System Controller (ASK)
    * Control Center, Center Console (BZM)
    * Control Display (CD)
    * GW Control Display(Gateway)
    * Controller (CON)
    * Antitheft Alarm System (DWA)
    * Rear-lid Lift (HKL)
    * Lights Module (LM/LM2)
    * Power Module (PM)
    * Rain/Light Sensor (RLS)
    * Satellite, A-Pilar, Left (SASL)
    * Satellite, A-Pilar, Right (SASR)
    * Satellite, B-Pilar, Left (SBSL)
    * Satellite, B-Pilar, Right (SBSR)
    * Satellite, Seat, Passenger (SSBF)
    * Satellite, Seat, Driver (SSFA)
    * Satellite, Seat, Rear (SSH)
    * Satellite, door, front left (STVL)
    * Satellite, door, front right (STVR)
    * Siren and Tilt Sensor (SINE)
    * Language Processing System
    * Steering Column
    * Door Modules, front passenger (TMBF)
    * Door Modules, passengers side, rear (TMBFT)
    * Door Modules, passenger door (TMBFT)
    * Door Modules, driver (TMFA)
    * Door Modules, drivers door (TMFAH)
    * Door Modules, drivers side, rear (TMFAT)
    * Wiper Module (WIM)
    * Cental Gateway Module (ZGM)
    * Safety and Information Module (SIM)
    Volvo
    Covers Volvo vehicles from 1996 to 2004 Retrieves diagnostic information on the engine, automatic transmissions, anti-lock brake systems (ABS), supplemental retraint system (SRS), Instrument cluster. Functions include:
    * Retreive Diagnostic Trouble Codes (DTCs)
    * Erase DTCs
    * Retrieve Data Stream
    * Perform Actuation tests
    * Reset service interval indicator
    ASIANS
    Daewoo
    Covers Daewoo OEM connectors and Daewoo software. from model years
    1996 to 2002. Features include:
    * Engine Control
    * Automatic Transmission
    * Anti-Lock Brake System (ABS)
    * SRS AirBag
    Honda and Acura
    Covers Honda and Acura vehicles from 1993 to 2005. Retrieve information on the engine, automatic transmissions, anti-lock brake systems (ABS), supplemental retraint system (SRS), EPS and more.
    Functions include:
    * Erase DTCs
    * Perform Functional tests
    * Reset ECUs
    Hyundai
    Covers Hyundai vehicles from 1989 to 2006 Retrieve diagnostic information on the engine, automatic transmissions, anti-lock brake systems (ABS), supplemental retraint system (SRS), Immobilizer, electronic power steering, and more. Functions
    Include:
    * Read Diagnostic Trouble Codes (DTCs)
    * Erase DTCs
    * Retrieve current data
    * Flight record
    * Actutation test
    * Password teaching/ changing
    * Learning/ Neutral/ limp home / air bleeding mode
    * Resetting adaptive values
    * Crushing information
    * EPS type recognition
    * EVAP test (DMTL test)
    * Version configuration
    KIA
    Covers Kia vehicles from 1994 to 2006. Retreive diagnostic information on engine, transmission, ABS, 4WD control, SRS, Electronic Powert Steering, Body Electronic System, etc. Functions
    Include:
    * Retrieve DTCs
    * Clear DTCs
    * Read current data
    * Perform actuation tests
    * Perform special functions including fuel trim reset, EVAP system test, Transmission adaptation reset, ABS brake bleed, etc.
    Nissan/ Infiniti
    Covers vehicle systems of Nissan and Infiniti vehicles from 1991 to 2007 (Both non CAN and CAN). Features include: * ACSD
    * Anti-lock Brake System (ABS)
    * Engine Control System (ENG)
    * In-vehicle Management System (IVMS)
    * Automatic Transmission (A/T)
    * ACT D/ SUS
    * HICAS
    * 4-Wheel Drive System
    * AirBag (SRS)
    * Smart Entrance System
    * Torque Converter System (NCVT)
    * Anti-Theft System (NATS)
    Mazda
    Covers 323,626,Mazda3 and Mazda6 and MPV vehicle systems from 1996 to 2005. The software support engine systems, transmission systems, anti-lock brake system (ABS) amd Supplemental Restraint System
    (SRS). Function includes:
    * Read trouble codes
    * Clear trouble code
    * Read data stream
    Mitsubishi
    Covers Mitsubishi vehicle systems from 1995 to 2005 (non CAN-bus).
    Features Include:
    * Engine (MPI/GDI/ Diesel)
    * Cruise Control
    * Automatic Transmission (ELC-AT/CVT)
    * 4-Wheel Drive
    * TCL - Stability Control
    * AirBag (SRS)
    * ECS
    * Full Auto Air Conditioning
    * (Seat) HBB
    * Immobilizer
    * Super Select (SS4 II)
    Toyota/ Lexus
    Covers Toyota and Lexus vehicles from 1992 to 2004. Features
    Include:
    * Engine and ECT
    * Rain Sensor
    * Cruise Control System (CCS)
    * Brake Systems (ABS/VCS/TRAC)
    * RTRCTBL Hardtop
    * Hyrid Battery (HV Battery)
    * AirBag (SRS)
    * Slide Roof
    * Hyrid ECU
    * Combination Switch
    * Steering Pad
    * Stop and Go
    * Air Conditioning
    * Tilt & Telesco
    * Sequential MT
    * Door
    * Adjustable Height Control (AHC)
    * Laser Cruise
    * Seat
    * Electric Power Steering (EMPS/EHPS)
    * Immobilizer
    * Gateway
    * Free-Tronic
    * Steering Lock
    * Meter
    * Tire Pressure
    * Theft Deferrent System (TDS)
    * Mirror
    Warranty : provide one year quality warranty .
    Price:$975(include shipping)
    If need more information PM me.
    Former Member TRPLXL2 has much to be proud of
    Jan 2009
    Norwalk, Ohio
    2 Post(s)
    1 Thread(s)
    Does this system have to be upgraded like a Tech II, because that alone is a couple grand right there. I have all Chevy vehicles, so what is a full description of what this will do for a Chevy vehicle. I saw it is mainly for foreign cars, but I could use a few of the options.
    Jul 2009
    Hi,at present this system can updated to A2800,this one cover was mentioned in the description ,but some cars are not cover.
    Jan 2009
    Norwalk, Ohio
    2 Post(s)
    1 Thread(s)
    Alright cool, I think I am going to wait for something that I can use a little more. This has a lot of wasted options that I can't really use, so thanks for the help again.
  5. #5
    Legend TrailLeadr has a reputation beyond reputeTrailLeadr has a reputation beyond repute
    Jun 2005
    Coventry, Rhode Island
    2 Post(s)
    1 Thread(s)
    That a new project you have in your siggy TRPLX2?
    Patrick
    Rhode Island
Similar Threads
  1. real uses for tools
    By MrShorty in forum Contests, Giveaways & Games
    Last Post: 11-03-2011, 09:52 PM
  2. A couple of tools to keep in the glove box
    By Dr_Zero in forum How-to Guides
    Last Post: 09-14-2009, 09:02 AM
  3. jack tools
    By whatzleft in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-24-2009, 12:36 PM
  4. Jack tools
    Last Post: 08-09-2009, 11:09 AM
  5. OBD I scanner
    By ct9a in forum General Chevy Tech Q&A
    Last Post: 07-02-2008, 05:46 PM
