Results 1 to 10 of 13
    Moderator
    Davandy's Avatar
    Jun 2005
    Haasdonk Belgium
    Default I have a water leak on one of the freeze plugs [Expired Topic]
    I have a water leak on one of the freeze plugs just above the engine support.
    Itís not possible to repair it without pulling the engine out, or is there any other way to do this?
    Peter Smet
    Haasdonk, Belgium
    If you can get to the freeze plug, it can be done without removing the engine, but if the support blocks it you may at least have to jack the engine up enough to gain access. Good luck. You might also try covering the leak with some J-B Weld. I have repaired a cracked block with it and it worked pretty good. If you try this, make sure the you have drained all of the coolant out of the block so the J-B Weld can cure properly without getting wet.
    Gary
    99 K 1500 Suburban
    00 S-10 Blazer
    1976 Trans Am
    1980 Honda CB900 Custom
    I had to pull the engine on my old 62 GMC because of lack of access when a freeze plug went out. Never thought about using JB weld for that, have used it on other projects though with a good result.
    Steve
    10 Chevy Traverse LT AWD
    Moderator
    Davandy's Avatar
    Jun 2005
    Haasdonk Belgium
    Here are some pictures of the hard work
    Peter Smet
    Haasdonk, Belgium
    Wow, were those pictures taken by NASA or some satellite! They're HUGE! I'm glad they're just links becuase they would double the size of the database!
    Steve
    Moderator
    Davandy's Avatar
    Jun 2005
    Haasdonk Belgium
    Sorry Steve I will see if I can get them smaller.
    They are taken with my digital camera 5 mega pixels
    Peter Smet
    Haasdonk, Belgium
    Moderator
    Davandy's Avatar
    Jun 2005
    Haasdonk Belgium
    Done
    Peter Smet
    Haasdonk, Belgium
    Hey, that's great. Are you keeping a photo record of what you're doing? I'll do a step-by-step how to change a bad freeze-plug article.
    Steve
    I know I'm going to regret asking but.
    Why didn't you just pull the motor? It looks like it would have been less work.
    And one Big Pain in the Ass When it Doesnít.
    See a Pattern yet?
    I gotta agree with 84fiero, looks like way more work than it had to be. at the most i would have unbolted the motor mounts and lifted the engine just enough to get to the offending plug, or maybe removed the exhaust manifold for access. pulling the engine does not require removal of the front clip, just the hood, unless you had no way of lifting the engine over the radiator support.
  1. Sevice 4WD???? [Expired Topic]
    By Jose in forum Chevy Avalanche Forum (Escalade EXT)
    Last Post: 02-19-2007, 06:56 PM
  2. Water inside the windshield glass [Expired Topic]
    By Tourmeline in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-02-2006, 07:58 AM
  3. New How-To forum [Expired Topic]
    By Steve in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 12-26-2005, 05:34 PM
  4. More boost? [Expired Topic]
    By Davandy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 08-15-2005, 03:59 PM
  5. Welcome [Expired Topic]
    Last Post: 06-16-2005, 11:57 AM
