Hello all,
I recently bought a '97 Silverado that is in great shape with 108,000 on the odometer. Have no complaints but the truck sits about an inch higher on the passenger side than it does on the driver's side. Anybody have any thoughts on what I need to do to correct this?
your driver side shocks might be worn out. Also, check all your suspension components to make sure nothing is broken or bent out of shape.
2000 Sierra ext. cab
5.3, auto, power everything, Pioneer AVH-2300DVD, Kenwood door speakers, 2-10" MA Audio subs, eBay cai, 1 chamber eBay muffler exiting before tire, 245/75 16 Wrangler Armortracs, 6500k HIDs with relay kit
1995 Cheyenne C1500 ext. cab(my baby, my first truck)
5.0, 5 speed, Silverado appearance package, power nothing, bucket seats and console Silverado, painted black interior, eBay halo headlights, eBay chrome tails, eBay cai, dual Flowmaster 40's w/no cats, 15x7 American Racing Hopsters, Walmart fog lights, SS mirrors
welcome to the site, what your referring to is the "chevy lean" my 97 was the same way i just cranked the torsion bar to raise the Driver side
2003 Z71 Silverado LS
Access roll up cover
Bed Rails
Billet Grill insert
Bed Rug
CB with PA system
Waiting to be installed
Thanks for the suggestions. That gives me couple of things to start on.
The issue has been brought up before. Seems like a pain in the butt.. not sure why there isn't a realistic fix (akin to getting a leveling kit to get the front end sitting where it should)
Welcome to the site!!!!!!!
Adjust your torsion bar.
BRYAN
"IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
02' Avalanche 2500 Onyx Black
8.1L Vortec
43,000 miles
The only time I've seen something like that befor was on an 04 Ford Ranger (I was a little rough with it). Her frame twisted a bit while offroading. Lesson: don't drink and drive!!!!!!.....especially over rocks and through ditches as this apparently can twist the frame.
-Greg
The fool learns not from the wise man, but the wise man from the fool.
2004 Silverado 4x4 (Suzie)
6" Fabtech Suspension Lift
35" NITTO Terra Grapplers
18" MB Wheels Predators
Thrush Turbo Series Mufflers
on true dual exhaust
Grille by Option Racing
1952 3600
Finally getting torn down to the frame.
MY 2002 did this also, my problem was the torsion bars were horrible out of wack. Check yours, it might be a simple fix like mine was.
2002 Chevrolet Silverado 1500 z71
6.5" BDS Suspension Lift Key'd to 9"
5.5" Lift Springs with 4" Blocks
35" Toyo Open Country Mud Terrain on 18" Ion Alloy 179's
AirAid Cold Air Intake with K&N Dry Filter & AirAid PowerAid Throttle Body Spacer
Pacesetter Long Tube Headers with Catalytic Converters Removed and True Dual Exhaust FlowPro Mufflers 4" Stainless Tips
Bosch +4 Iridium Spark Plugs MSD Ignition Plug Wires
Innovate LC-1 Wideband o2 Sensor x2
BDS Dual Steering Stabilizers
Electric Fan
4.56 Gears
EFI Live
Sounds like a nice truck and welcome to the forum!
2009 GMC Sierra Denali AWD
Park the truck on level ground and log the measurements at all 4 corners on a notepad.
You can either use a spot on the frame to the ground or measure from the top of the tire to the fender lip (either spot will work).
Determine which corner is the most out of whack, it might not be as simple as crank one side up, you may need to pull the other side down some or you could have an issue with the rear springs forcing a corner up or down.
Since the rear springs are harder to adjust most of the adjustment will come from the front.
Adjust the torsion bars a little at a time, after adjusting them bounce the truck up and down a few times to allow the suspension to settle then measure all 4 corners again, repeat as necessary until the truck sits to your satisfaction. After adjusting the torsion bars keep an eye on the tire wear, you may need to have an alignment done to correct the front geometry.
Tim
2011 Silverado 1500 LT
2008 HHR LT
1999 Tacoma SR5 TRD 4X4
1993 Jeep Wrangler
1991 Toyota Rock Crawler
2009 Harley Davidson Nightrain
2004 Harley Davidson FLHT "Bagger"
2003 Glastron GXL Bowrider
Bookmarks
