    Default Convert Front Valance
    I bought an '04 2500HD that didn't have the tow hooks or the front valance that will accept them.
    My valance had no openings and was in great shape.
    Rather than spend the $$$ on a new one with hook openings or a used one with problems, I decided to convert what I had.
    It's pretty simple. First remove the lower valance.
    Note: All of the work is done on the back side of the valance.
    From the back side, sand down the innermost coves on the edges. Use a small handsander with large grit. It takes some time to get to the point where you can see where it wants to release. This plastic is TOUGH! It took me about 20 solid minutes on each opening. Remember, you only need to be concerned with sanding the point where the plastic connects on the fold - you don't need to sand the entire opening.
    Once you get close, get aggressive and work the areas that need help. Get it to release on its own if possible so it looks factory smooth. One side of mine released easier than the other.
    At a point you can just pop it out. Don't do it too soon - the plastic gets pliable since it's warm and will tear into good plastic if you haven't removed enough for a clean release. Use the edge of a blade and drag (not cut!) it around the edge of the cutout to remove any hairs. You can also use some finer grade sandpaper to hit the edges.
    Remember, when you do any cutting or sanding stay on the area that was removed - any cutting into new plastic, well, looks like you just cut into new plastic. This is what we're trying to avoid.
    Mounted the valance back up and I was very pleased with the results. Looks factory, saved me some $$ and I don't have an extra valance to add to my spare parts pile.
    Now I just need to install my ordered hooks.
    great how to, think it would work for the fog lights holes also? and i will toss one of these in
    nice how to, but
    Quote Originally Posted by 5speedsilverado View Post
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
    I agree.
    Sorry.
    I wasn't doing the alteration for the how-to post and thought about sharing it after the fact (and since it came out so well).
    I thought about fog lights but I'm not sure how they mount and if they use any of the valance. If they just need the valance opened it should work just the same.
    yeah i think that is all, idk, if someone here has original fog lights, maybe they could post pictures?
    you could still post pics of the after, if its not to hard
    Jr. Engineer
    Feb 2007
    Edmonton, Alberta, Canada
    did someone say we should get a picture?
    1993 K1500 Suburban 350TBI, 378,486KMS on frame, 49,000KMS on Drivetrain. Lots of mods, built for haulin trailers and haulin @$$ :)
    2000 K2500 Yukon XL 6.0L Vortec 252000KMS custom CAI, and exhaust...but not done yet.
    "If you are dumb enough to do something you don't know how to do, and can't do it safely then WHEN you get hurt its your own fault...BONEHEAD"
    Shamed into after-the-fact pics.
    Not sure how much help they'll be but here they are.
    This is what was sanded away and removed
    A nice clean opening
    You remove the valance and sand from the back side
    Another clean opening
    Wow I was kind of wondering how those holes came out, I was seriously doubting what you were saying in your original post. Now that I see it that is awesome, I have to remove those out of my new truck and I am dreading it because mine won't come out like that. Great job though, that has got to be the cleanest removal of those I have ever seen.
    wow that does look factory, great job
    i took some pictures of mine, it does look like the valance without fog light holes has the mounting bracket for fog lights.but it is on the chrome piece, not the valance. I also took a picture of my tow hook.
  1. Convert 2wd to 4x4
    By Pats1pab1 in forum GM Powertrain
    Last: 04-23-2010, 08:56 PM
  2. 1995 GMCTruck Suburban convert to Standard front end??
    By 4DGS in forum Chevy Truck Accessories
    Last: 11-20-2009, 11:00 AM
  3. 2x4 convert to a 4x4
    By tankers1985 in forum General Chevy & GM Tech Questions
    Last: 09-07-2009, 07:55 PM
  4. 06 Suburban LTZ front valance
    By 99fxst99 in forum General Chevy & GM Tech Questions
    Last: 04-14-2008, 02:23 PM
  5. Convert S-10
    By ChevyFan in forum Chevy S10 Forum (GMC Sonoma)
    Last: 05-27-2007, 03:10 PM
