Results 1 to 4 of 4
    Jr. Apprentice mkruluts is a glorious beacon of light
    Jun 2009
    Pittsburgh, PA
    Default Truck Brakes Make Noise. Help Please!
    Ok, a few months back my 2005 Chevrolet Silverado w/ Z71 suspension package, was taken in for inspection. The truck never made a single noise, it was immaculate. The only problem, in a dry part of january I put my foot on the brake and didn't stop (atleast until I hit the guy in front of me). When I got the truck inspected, they replaced the front rotors and all the brakes. For the first month everything was fine. However, for the last couple of months the brakes have making a noise. It sounds like it is coming from the front driver side, and only happens when I am driving straight and don't have my foot on the brake. When I turn or go to stop, the brakes don't make a noise. Any way, my question is... is there a replacement brake that won't make this noise? I asked someone about it, and they said the material that the OEM brakes were made from is not allowed to be used anymore?
    Legend bob13 is a glorious beacon of light
    Feb 2009
    NE Pensylvania
    Can you duplicate the noise by jacking the truck up and spinning the wheel? Is it a grind, squeal........etc.
    The diference between stupidity and genius is that genius has limits.
    2007 NBS Silverado
    LT2 Z71
    2.5" Levelling Kit
    Hood Stripes
    Chrome Grill
    GM Bed Liner & Tonno
    Dick Cepek Rims 18X9
    Hankook RF10 Tires 275/65/18
    De-Badged Tailgate
    More Mods Coming
    Jun 2009
    Pittsburgh, PA
    I don't really have the time to jack it up... but if it helps, the noise is a squeal. It doesn't grind, it just annoys.
    Legend dsfloyd has a brilliant future
    May 2009
    San Diego CA
    3 Post(s)
    the squeal while not braking is typical of the squeaker tab on the brake pad. Since a month is kind of quick to wear a brake pad check to see if it is just bent and hitting the rotor. If the pad is actually worn down and its just one then you need to look at possibly a bad caliper. Need to pull the wheel and look to see if something is rubbing.
    David
    2004 Silverado 2500 Crew Cab 4x4, Airraid cold air intake, Throttle body spacer, Magnaflow exhaust (true dual to 2 in 1 out muffler), 6" ProComp lift (add a leaf and 5" superlift rear block), Bilstein shocks, 35's (Cooper Disoverer ST's) and 4.10 gears, Rhino Liner, fiberglass tonneau cover, extended stainless steel brake lines, firestone airbags.
    1960 Land Rover Series II 88
    2002 Nissan Altima (wife's Car)
    1999 Saturn SC1 (the new commuter car)
Similar Threads
  1. That Noise...Make It Stop!!
    By mrcaddy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-04-2010, 08:01 AM
  2. Did GM ever make this truck?
    By Paulstrazz in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 02-08-2010, 09:33 AM
  3. Make some noise! Who's ready for a contest???
    By Steve in forum Contests, Giveaways & Games
    Last Post: 09-12-2009, 12:11 AM
  4. Here to make my good truck better
    By gkswets1014 in forum Member Introductions
    Last Post: 05-18-2009, 06:40 PM
  5. Let's make noise!
    By ceedeerrr in forum The Coffee Shop
    Last Post: 12-29-2006, 12:37 PM
