    Jr. Apprentice ohiomossyoak's Avatar
    Nov 2010
    Brownsville ,Ohio
    Default Oil cooler line question.,.HELP
    I got a 95 K1500 Suburban with a 5.7 in it..I was removing the radiator to have it repaired an i twisted an messed up the lower Oil cooler line...The return line i think???So i got a replacement line..I got the line installed..But i got a drip on the oil filter side of the line(not radiator side)..My question is this..There are 3 pieces that i am unsure of there order...There is the paint in the butt clip,,a rubber O ring,an a round plastic ring..What order do these go in???I know the clip goes on the line but then what..I have the plastic ring next then the rubber O ring..Is that correct..Or is it Clip,o ring,round plastic ring???/Any help is greatly appreciated
    Thanks Nick
    Father,Husband,Bowhunter
    95 K1500 Suburban---5.7=350ci
    Sr. Mechanic Ethan's Avatar
    Sep 2009
    Cedar Park, TX
    O-ring goes on the line, it makes the actual seal between the line and whatever it's called you're mounting it to, the plastic ring is a spacer so the clip will keep pressure on the line..if that makes any sense...didn't you get any instructions on how to do this from the place you got the parts? It should of came with instructions.
    1994 Chevy Silverado 1500 Ext Cab 350 cuin TBI in dark Chevy blue
    160,000+ miles
    Original paint
    Original interior
    Original engine and tranny
    wrecked twice stolen once
    Diamond Plate bed rails
    Power windows
    Original Alloy wheels
    Original fancy smancy cup holder
    Tow package
    Original plastic bed liner
    K&N Cone Air Intake
    Dual MagnaFlow exhaust(not true dual) with chrome tips
    MSD Street Fire Performance Ignition coil
    Nov 2010
    Brownsville ,Ohio
    Quote Originally Posted by Ethan View Post
    Nope no instructions...Sounds like I got it installed in the correct order..The spacer is in the middle..So I must have a small leak from the whole thing just not being fully engaged I hope..My oil level has not went down in over 300miles..But I do get a few drops of oil on the ground here an there
  1. Oil cooler line replacement
    By Blue Roan in forum GM Powertrain
    Last: 05-19-2011, 07:47 AM
  2. Oil cooler line replacement 2003 suburban 8.1L
    By Woodman in forum General Chevy & GM Tech Questions
    Last: 01-22-2011, 07:46 PM
  3. 2008 Silverado Transmission Cooler Question
    By carrfire in forum GM Powertrain
    Last: 06-10-2010, 09:34 AM
  4. Oil cooler line install question
    By HeavyMetalMechanic in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-31-2010, 05:19 PM
  5. cooler line,tranny failure,
    By gardnergrendal in forum GM Powertrain
    Last: 06-12-2009, 08:44 PM
