Results 1 to 3 of 3
    Newbie cocacolamanjosh1984 is a glorious beacon of light
    Aug 2008
    texas
    Default a/c blower issues 04 tahoe
    on my 04 tahoe, (seperate temp selections for driver and rider) when i put my blower selector on number 4 it stops, if i bump it or turn it to 5 then back down, it will start working again. I got 87091 miles and 2500 hours, any ideas? thanks guys any ideas on fixes and costs
    Jr. Apprentice bowwow is a glorious beacon of light
    Aug 2009
    Default could be resistor
    I just replace the blower motor resistor in my Daughter's 04 tahoe. pos 5 was the only one that would work. If you bang on the sw and it starts working it could possibly be a bad connection. But if the blower won't work on any of the positions 1 thru 5 it could be a bad resistor. Mind cost about 66 bucks with tax at the dealer. Be aware if the original resistor has a snap on cover on it and will not fit over the new resistor you discard the cover and install the resistor without it. On my Daughter's 04 Tahoe it was located on the pass side near the floor you have to remove the large black cover that has 3 or 4 screws from underneth, the resistor is mouted towards the right bottom just by the blower it has two mount screws and drops stright down to come out. The pigtai wire connector to the blower is a little trickey to get but if you lean right down with your head on the floor you can see it. It was not all that bad to change. Good luck with your fix.
    Legend dsfloyd has a brilliant future
    May 2009
    San Diego CA
    3 Post(s)
    It could also be the control module. In my truck it wasn't the fan selector but the position selector that wasn't working right and thats what it ended up being.
    David
    2004 Silverado 2500 Crew Cab 4x4, Airraid cold air intake, Throttle body spacer, Magnaflow exhaust (true dual to 2 in 1 out muffler), 6" ProComp lift (add a leaf and 5" superlift rear block), Bilstein shocks, 35's (Cooper Disoverer ST's) and 4.10 gears, Rhino Liner, fiberglass tonneau cover, extended stainless steel brake lines, firestone airbags.
    1960 Land Rover Series II 88
    2002 Nissan Altima (wife's Car)
    1999 Saturn SC1 (the new commuter car)
Similar Threads
  1. Blower issues on 03 Trailblazer
    By badgerjsr in forum General Chevy Tech Q&A
    Last Post: 06-14-2010, 04:17 PM
  2. 2008 Tahoe pdl and handle issues
    By justaphase44 in forum General Chevy Tech Q&A
    Last Post: 05-31-2010, 09:26 PM
  3. new owner of 07 Tahoe LTZ - issues
    By Logman96 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 02-01-2010, 07:55 PM
  4. help with tahoe blower
    By bowwow in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 08-28-2009, 02:54 PM
  5. '97 Tahoe Blower inop
    By michaelbell317 in forum Audio / Video Electrical
    Last Post: 11-04-2008, 04:23 PM
