GM Truck Club
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Legend
    Feb 2008
    Red Wing, Minnesota, United States
    I understand the the whole AC Delco thing, but I know when you go down to an auto parts store and get plugs they say .060 GAP for the 5.7 so why go down to .040
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
  2. #12
    Quote Originally Posted by 2COR517 View Post
    Those big gaps puts a tremendous load on the entire ignition system. Coil, cap, rotor. GM issued a bulletin some years ago to crank the gaps back down to .040. I did it in my truck, made a huge difference.
    Apparently it wasn't a TSB, but something they issued through their dealer network. It probably takes five times the energy to spark the larger gap.
  3. #13
    Newbie
    May 2009
    North central IN. Macy
    You might want to chk those wires out again. I got a poor set from the zone 1 time yrs ago. I do not use inexpensive ignition parts anymore. Don't pay!
  4. #14
    Quote Originally Posted by wildolman View Post
    Same here! AC Delco all the way. They are actually cheaper than Napa. NAPA BlueMax wires are OK though.
  5. #15
    Legend
    Feb 2008
    So what was the difference by going to a smaller gap, did you notice better starting, or difference in MPG or throttle response
    285/75/16
    Jason
  6. #16
    Everything is better. Most noticeably ilde is smoother, no more pinging/detonation, and more power overall.
    Apparently, GM tried big gaps in the 70's, 80's, and 90's. And each time after a few years they issued new guidance to take the gap down to .040.
  7. #17
    The problem is not the plugs, wires, cap, etc as i swapped them out already with no change. i will start preparing for the leak down test and see what it shows. thanks for all of the replys.
  8. #18
    Default similar issue
    Quote Originally Posted by L0sts0ul View Post
    check your compression, sounds to me like a head gasket leak on possibly both sides or even a crack in the block... could be a craked head too...
    coolant in the exhaust (in my experience) has always come from cracked heads, or head gaskets.
    I have no coolant in my exhaust, though...thoughts?
    Carbon footprint? What carbon footprint?
  9. #19
    Sr. Apprentice hmaster77's Avatar
    Jun 2009
    Kingsville/San Marcos TX
    the gapping will stop the miss fire but the coolant leak is more than likely a blown or leaky headgasket or cracked head does the van ever overheat?
    2008 chevy silverado single cab short bed 4.3
    1960 chevy apache 10 single cab short bed 3.9
    1986 chevy 1 ton flatbed 5.7 (deceased)
    1990 suburban regency edition 5.7 (sold
  10. #20
    Jr. Engineer
    Feb 2007
    Edmonton, Alberta, Canada
    This is the exact reason to use the MSD 6 box with msd coil, and wires. I have successfull run .065 gap using this setup, and haven't had any problems.
    1993 K1500 Suburban 350TBI, 378,486KMS on frame, 49,000KMS on Drivetrain. Lots of mods, built for haulin trailers and haulin @$$ :)
    2000 K2500 Yukon XL 6.0L Vortec 252000KMS custom CAI, and exhaust...but not done yet.
    "If you are dumb enough to do something you don't know how to do, and can't do it safely then WHEN you get hurt its your own fault...BONEHEAD"
Similar Threads
  1. 2001 silverado misfiring
    By pramitor in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-17-2010, 02:32 PM
  2. Huge misfiring problem
    By siavreg10 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-26-2009, 12:05 AM
  3. 2003 Chevy Suburban 8,1 liter Vortec LT Autoride 4x4
    By Ronny in forum Photo & Video Gallery
    Last Post: 03-14-2009, 08:26 PM
  4. I Need Gears Badly! Help!!!!!
    By GM_Guy in forum Lifted & Offroad Suspension
    Last Post: 10-03-2007, 06:58 PM
  5. 1999 v4 Sonoma badly squeaking
    By Burger7 in forum Chevy S10 Forum (GMC Sonoma)
    Last Post: 09-20-2006, 09:37 PM
