Results 1 to 7 of 7
    Newbie ccpotter is a glorious beacon of light
    Jul 2009
    St. Paul, MN
    Default What to Grease on GM Truck
    I have been changing my own oil for sometime now and am not sure what I should be greasing on the chassis that a dealer would be doing if I took it in for an oil change. Can anyone offer any insight on what zerts or areas I should be lubricating every 3,000 miles? Thanks in advance!
    CP
    Master Mechanic Darknesss23 is a name known to all
    Jun 2008
    Brookfield, Ct.
    1 Thread(s)
    I(and by I i mean my family) have an industrial parts business (bearings, belts, gears, chains, sprockets, pulley's, Hydraulic hose, etc) ... I can't answer "where" on the truck you should be greasing i can only tell you that if you're greasing certain bearing housing... not to grease it too much... Many people make the mistake of pumping grease into a bearing housing until they see grease ooze out of the crevasse's/joints... DO NOT do this. 1-2 pumps of a grease gun is more than suffice in some areas. If it is over-greased, dirt sticks to the grease that has oozed out and finds its way inside the moving parts and eventually causing premature wear...
    2008 Chevrolet Silverado 1500 LTZ 5.3L EC/Std Bed 4x4 Flexfuel
    Full Metal Jacket Spray on Bed Liner
    Black Powder coat Diamond Plate Weatherguard Tool Box
    Corsa Performance Sport Exhaust System
    K&N Flat Panel OEM replacement Air Filter
    Bridgestone Dueler A/T Revo tires P275/55/R20
    Black Reflective pinstripe and VORTEC hood lettering
    Billet front bowtie
    Rear Bowtie Delete
    Blue strobe grille lights
    Blue strobe rear window lights
    Blue LED Mini Light bar in front Grille
    Legend
    99'HEARTBEAT has a reputation beyond repute
    Apr 2009
    2 Post(s)
    You did not mention what year Truck you have,but here is a link that should help you out,
    http://www.mytractorforum.com/showthread.php?p=104084
    MIKE
    99".....SILVERADO....5.3 LITER / 3.73
    Legend 2COR517 has a reputation beyond repute
    May 2009
    Maine
    My 97 K2500 and 95 Tahoe have the same eleven fittings, plus the front driveshaft slip yoke. Upper and lower ball joints, both sides. Outer and inner tie rod ends, both sides. Pitman arm at center link, idler arm at center link and idler arm shaft at frame mount.
    If your U-joints have grease fittings, you should do them if you can. I hate u-joints with grease fittings, they never last for me.
  5. #5
    Jr. Apprentice Offshore24 is a glorious beacon of light
    Feb 2009
    Maine
    When I got my new/used 1500 I thought my front end needed lubing. Steering column was rattling when turning. I found all the zerks and lubed everything (tip - take the front wheels off) and still rattling. I'd also recommend a Chilton's manual.
    2007 Silverado Classic, 5.3L, Ext Cab, 4wd, LT2.
  6. #6
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by Offshore24 View Post
    There is a repair for your noisy column. It entails drilling a hole, installing a grease zerk, and filling it up with grease. Do a search here and you will find it.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
  7. #7
    Feb 2009
    Maine
    Quote Originally Posted by Jimmiee View Post
    I saw that. I'm thinking I want to get GM to replace the I shaft first then if that doesn't fix it I can go it alone. My warranty is good till Dec of this year.Thanks.
Similar Threads
  1. Where are the grease nipples on my truck?
    By Bigbomber in forum General Chevy Tech Q&A
    Last Post: 04-25-2010, 10:24 AM
  2. Need grease?
    By 1st Synthetics in forum 1st Synthetics
    Last Post: 03-22-2009, 08:24 PM
  3. under truck grease zerks?
    By jbhofc in forum Lifted & Offroad Suspension
    Last Post: 01-29-2008, 11:04 PM
  4. Grease Zerks?
    By jbhofc in forum General Chevy Tech Q&A
    Last Post: 01-27-2008, 11:29 PM
  5. grease zerks under truck????
    By jbhofc in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-25-2008, 08:10 PM
