Results 1 to 7 of 7
    Jr. Engineer Falcone is a glorious beacon of light
    Apr 2009
    Toronto, Canada
    Default 2.8L swap to a 4.3, how much does it take?
    So I think I found out the 2.8 is a 60* and the 4.3 is a 90*, So the trans won't work, so I need the whole kit and kaboodle out of a donor truck? engine, trans, driveshaft and rearend? How about wiring?
    2010 Sierra Nevada Edition
    4.8L Ext. cab - Black Z85 4x4 G80
    Shaved a couple badges and 4x4 stickers, DeeZee Red label Low Pro gloss black Brite plate cross box,DeeZee gloss black Brite plate bed rail caps , K&N,more to come.
    Legend retired2001 is a glorious beacon of light
    Nov 2006
    Canyon Lake, Texas
    You guessed it! There are a lot of donors out there, good luick!
    2010 Z/71 Colorado C/C
    Black 4X4 w/5.3L V8
    2007 Winnebago Adventurer
    w/8.1L Chevy & Allison 6spd.
    Canyon Lake, Texas
    Sr. Mechanic 1_low_rider is a glorious beacon of light
    Apr 2009
    Mississippi
    i do believe you will need the wiring harness as well......is this your daily driver or a project??
    Scott-Mississippi
    2002 Silverado
    *Stock 5.3 engine
    *DJM 5/7 lowering kit
    *20in. Boss 330 wheels on 255/35's
    *3in. BBK headers into dual 1chamber Flows
    *Airaid Coldair Intake and Hypertech programmer
    *Shaved doors, tailgate, taillights, 3rd brake, and stake pockets
    *Smooth roll pan with tag and LED brake lights frenched into tailgate
    4 SALE - $6000 Firm
    Legend 5speedsilverado is a glorious beacon of light
    Mar 2009
    peoria arizona
    tranny is a nv3500 with the 4.3, you should do a 4.8 or 5.3 swap, if you have to do all that
  5. #5
    Apr 2009
    Toronto, Canada
    this is my daily driver currently. when it comes time for the swap hopfully it'll be a bit of a project truck
  6. #6
    Apr 2009
    Toronto, Canada
    my buddy was telling me about the 3400 out of a grandam and how it would bolt almost right up with just a few minor wire extentions , what do you guys think of those?
  7. #7
    Jr. Apprentice MTchevy1 is a glorious beacon of light
    Jul 2009
    I believe the 3400 in a grand am is an overhead cam, which would mean a lot more than a few wires being extended. If you want a bigger motor but also want to keep things basic, just get a 3.4 out of an early to mid 90's camaro or firebird. Your intake and fuel injection will bolt right on, and your computer will run it just fine. It's a direct swap... pull out the 2.8, bolt all your accessories and top end on the 3.4, and put it in.
    If you have some cash to play with, GM sells it as a crate motor. It's meant to be a direct swap for your 2.8, and is 40hp more. Throw some headers and a few other bolt ons at it, and you're making the power of a 4.3 without any of the hassle!
    94 s10- 383cid, 4L60
    97 s10- 350cid, NV3500
Similar Threads
  1. 5.3 Cam Swap?
    By ajfdirtrider in forum Performance & Fuel
    Last Post: 03-12-2010, 12:04 PM
  2. 350 swap
    By lvaubel in forum General Chevy Tech Q&A
    Last Post: 10-26-2009, 09:55 AM
  3. rear end swap or gear swap
    By rmagni in forum Powertrain
    Last Post: 08-18-2009, 08:42 PM
  4. Swap 350 for 454...what needs to be done?
    By rzhorne in forum General Chevy Tech Q&A
    Last Post: 07-15-2009, 03:47 PM
  5. 5.3 swap
    By devilsalmostfree in forum Powertrain
    Last Post: 01-19-2009, 09:32 PM
