Results 1 to 10 of 14
    Feb 2009
    Chelmsford, MA
    Default Plugs and Wires???
    So I have read every post the search function could find relating to the selection of plug wires and plugs and everything I read seems to be about earlier models, say 2005 and earlier. I have a 2006 Silverado, 4x4 Ext Cab LT3 with the 5.3L V8. It just turned 70,000 so I thought it might be time for some new plugs and wires.
    From the posts I read the consensus on plugs seemed to be either AC Delco or NGK. Does the same hold true for my truck? Do type of plugs came stock in my truck, copper, platinum, iridium?
    For wires all summit shows are some Taylor's (cheapest), AC Delco which is obviously the factory option, and then Granatelli's which are by the far the most expensive but say they offer near 0 Ohms resistance. The Taylor's say they offer 500 Ohms resistance which doesnt seem to be much better than stock but they are much cheaper.
    What other options have you guys used? What do you suggest?
    As far as Wires,there are many to choose from,MSD,Taylor,JBA to name a few.IMO going with one of the ones I have Mention they will be a upgrade over Stock the one's,as far as Plug's I have gone with A/C Delco Iridium Plug's and JBA 8mm Wires,This has been a Very Good setup for me.
    Feb 2009
    Chelmsford, MA
    This is exactly my point. I did all this research and decided to go with the AC Delco Iridium plugs and the MSD SuperConductor wires but when I search for my model year none of these appear to be available.
    IIRC, your 99 has the 5.3L 323ci engine and I have the 5.3L 325ci engine. Are the plugs and wires on these 2 engines interchangeable?
    What am I missing?
    Quote Originally Posted by brtt485 View Post
    What am I missing?
    I don't see Why Not?? I just looked up Plugs and Plug wires at Summitt and here is what I found,
    http://www.summitracing.com/parts/MSD-32829/Application/?query=Year|2005|Make|CHEVROLET|Model|SILVERADO+15 00&prefilter=1
    http://www.summitracing.com/parts/ACF-41-985/Application/?query=Year|2005|Make|CHEVROLET|Model|SILVERADO+15 00&prefilter=1
    The H.P.in your truck has more,but the ci I Believe is still the same 323ci,Maybe someone can help me out on that.
    Go back and look up 2006, which is my model year, and tell me what you see then.
    My Bad,I looked up the wrong yr,Sorry.
    Feb 2009
    Chelmsford, MA
    You see what I mean though? I almost have zero options.
    Here are Plugs for a 2006 Silverado with a 5.3,325ci,
    http://www.summitracing.com/parts/ACF-41-985/Application/?query=Year|2006|Make|CHEVROLET|Model|SILVERADO+15 00&prefilter=1
    it is the same Spark Plug that is used in a 99' Silverado 5.3 liter 323 ci
    Feb 2009
    Chelmsford, MA
    Yeah, the plugs were an easy find luckily! Always plenty of options on those. What I am really after is a good aftermarket set of wires with very low resistance. I havent tested the stock wires but others have said they are around 600 Ohms. The MSD wires are down around 50 Ohms.
    I have Bosch +4 plugs, and MSD Ignition performance wires. I noticed a good increase in throttle response, and in how easy it is to start my truck.
    www.youtube.com/ippielb
  1. Spark Plugs/Wires
    By Metaluzc in forum Performance & Fuel
    Last Post: 02-21-2010, 07:31 PM
  2. new plugs and wires
    By tmcroc24 in forum Performance & Fuel
    Last Post: 12-27-2009, 07:22 PM
  3. new plugs and wires
    By dsfloyd in forum Performance & Fuel
    Last Post: 10-29-2009, 04:29 PM
  4. New Plugs and Wires
    Last Post: 06-18-2009, 11:15 AM
  5. plugs and wires for 01
    By etpn13 in forum Performance & Fuel
    Last Post: 03-23-2009, 08:38 AM
