I want to change the fuel filter on my 04 2500HD w/6.0 Vortec.
This may sound very basic, but I don't know the correct answer.
Since I don't have anything to bleed the pressure off, could I be causing any problems changing it without the bleeding tools?
i never bleed it just crack it open and let it spit, or you can take the gas cap off to release the pressure in the tank
2003 Z71 Silverado LS
Access roll up cover
Bed Rails
Billet Grill insert
Bed Rug
CB with PA system
Waiting to be installed
I thought the fuel filter was in the tank on the 04??
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
That's what I was planning to do. Thanks.
I need to double-check but I'm about positive the filter's on the frame.
check the frame but I think its in the tank, and then would usually be a screen more than a filter (I kind of remember checking it once before). I could be confusing it with my altima since I know that is where it is on that car.
David
2004 Silverado 2500 Crew Cab 4x4, Airraid cold air intake, Throttle body spacer, Magnaflow exhaust (true dual to 2 in 1 out muffler), 6" ProComp lift (add a leaf and 5" superlift rear block), Bilstein shocks, 35's (Cooper Disoverer ST's) and 4.10 gears, Rhino Liner, fiberglass tonneau cover, extended stainless steel brake lines, firestone airbags.
1960 Land Rover Series II 88
2002 Nissan Altima (wife's Car)
1999 Saturn SC1 (the new commuter car)
On my wife's 04 Tahoe I had to buy a tool to get it off. It takes a special tool to get it off and I cant remember the name of it. Just in case you didnt know.
2003 Avalanche 4x4 110k mil.
On my 2002 and my dads 2000, it's attached to the frame with a clamp, in front of the gas tank, towards the driver. All i did, was open it up all the way, and let it all spill out. Oh and a little advise, when you're under your truck, go to the side of your filter, not directly underneath it. I ALMOST made that mistake. Haha
2002 Chevrolet Silverado 1500 z71
6.5" BDS Suspension Lift Key'd to 9"
5.5" Lift Springs with 4" Blocks
35" Toyo Open Country Mud Terrain on 18" Ion Alloy 179's
AirAid Cold Air Intake with K&N Dry Filter & AirAid PowerAid Throttle Body Spacer
Pacesetter Long Tube Headers with Catalytic Converters Removed and True Dual Exhaust FlowPro Mufflers 4" Stainless Tips
Bosch +4 Iridium Spark Plugs MSD Ignition Plug Wires
Innovate LC-1 Wideband o2 Sensor x2
BDS Dual Steering Stabilizers
Electric Fan
4.56 Gears
EFI Live
On my 03 it is on the frame..
Starting with Model year 2004's,there is no Fuel filter.It has been this way Since the introduction of the high pressure returnless fuel system.
Here is a Good article about the Fuel Filters,
http://www.underhoodservice.com/Arti...n_systems.aspx
MIKE
99".....SILVERADO....5.3 LITER / 3.73
Jim
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1970 Camaro
2007 FJ Cruiser
Bookmarks
