Results 1 to 5 of 5
    Newbie LooseNut is a glorious beacon of light
    Jul 2009
    Default 285X70R - 17's on 02 1500 EXT. CAB
    Hi All,
    Newbie to the site, long time Chevy Truck owner/abuser.
    I currently have a 2002 Silverado 1500 Ext. cab truck, loaded, leather int, full power etc. etc.
    This is my year round daily driver and tow rig.
    I am planning on getting some new tires soon, probably this weekend,
    the original tire size is P265x75r-16's, right now I have a set of LT265X75R-16's.
    I have a new set of 17x8 Centerline wheels so I gotta get 17" tires.
    I need some info on tire size options.
    I would like to go up to 285x70R-17 tires but I am concerned about any potential problems with power loss, fuel mileage, and or transmission/speedo problems etc. Also, should I get a leveling kit?
    I guess I am getting old, in the past I would not have hesitated...
    Also, I want aggressive all season tires or mild All-Terrains.
    And some of the tires I am looking at only come in a 10-ply rating,
    For what I use this truck for all I really need is a P-type tire.
    How much will the 10-ply tires hurt my ride?
    And one more question.
    In cruising different tire dealer web-sites, some of the vehicle selection choices list a 1500HD whats differnt between a regular 1500 and 1500HD?
    And how do I tell what I have?
    Thanks in advance for suggestions and info.
    LooseNut
    Duluth, MN
    Legend dsfloyd has a brilliant future
    May 2009
    San Diego CA
    3 Post(s)
    easiest way to tell 1500 from 1500HD is 6 lug or 8 lug. 8 lug is the HD. The LT is not going to really hurt your ride any but you will definately want those if you ever tow/haul. LT just better for the heavy weight of the truck
    David
    2004 Silverado 2500 Crew Cab 4x4, Airraid cold air intake, Throttle body spacer, Magnaflow exhaust (true dual to 2 in 1 out muffler), 6" ProComp lift (add a leaf and 5" superlift rear block), Bilstein shocks, 35's (Cooper Disoverer ST's) and 4.10 gears, Rhino Liner, fiberglass tonneau cover, extended stainless steel brake lines, firestone airbags.
    1960 Land Rover Series II 88
    2002 Nissan Altima (wife's Car)
    1999 Saturn SC1 (the new commuter car)
    Legend kgibson181 is a splendid one to behold
    Jul 2009
    Cedar Grove, NC
    Any size bigger than the stock tire is going to throw your speedometer just because of the revolutions per mile that the speedometer is set to is set to the stock tire readings. As far as worse gas mileage, with all terrain tires that is less of an issue as it is with mud terrain tires. If you have alot of clearance in the fender well with the 265's and 16 inch rims you should be able to fit the 285's and new rims. If theres not alot of room I would go ahead with the leveling kit. The 10ply tires wont cause a rough ride just a difference from stock.
    2003 Silverado 1500
    V8 4.8L 294ci
    2 inch Pro Comp Leveling Kit
    3 inch Rough Country Lift
    33 inch Nitto Terra Grapplers
    5% Tint All Around
    2 12" Kenwoods
    Legend
    ippielb is a name known to all
    Feb 2009
    Canada
    With my 2002 silverado, I fit 285's with stock height, no rubbing no nothing.
    See?
    2002 Chevrolet Silverado 1500 z71
    6.5" BDS Suspension Lift Key'd to 9"
    5.5" Lift Springs with 4" Blocks
    35" Toyo Open Country Mud Terrain on 18" Ion Alloy 179's
    AirAid Cold Air Intake with K&N Dry Filter & AirAid PowerAid Throttle Body Spacer
    Pacesetter Long Tube Headers with Catalytic Converters Removed and True Dual Exhaust FlowPro Mufflers 4" Stainless Tips
    Bosch +4 Iridium Spark Plugs MSD Ignition Plug Wires
    Innovate LC-1 Wideband o2 Sensor x2
    BDS Dual Steering Stabilizers
    Electric Fan
    4.56 Gears
    EFI Live
  5. #5
    Sr. Apprentice jrose7 is a glorious beacon of light
    May 2008
    Wilson, N.C.
    I had 285"s on my stock 16" rims with no problems...I have 22" rims now and and run 305's. My total height is almost 2" over stock, with more than enough room. Check out this site; it gives you all the info you asked about. www.discounttire.com/dtcs/infoTireMath.dos
    jack
    2004 Ext. cab Silverado
    5.3L; Fujita CAI; Airaid throttle body spacer;
    Hypertech programmer;
    305x40x9.5 on Panther 22's
Similar Threads
  1. 35x12.5 17's
    By myfirstgixxer600 in forum Lifted & Offroad Suspension
    Last Post: 06-09-2010, 07:18 AM
  2. Replies: 0
    Last Post: 11-26-2009, 02:20 AM
  3. using 16's if 17's came stock?
    By ridnrimz in forum Lifted & Offroad Suspension
    Last Post: 10-15-2009, 02:22 PM
  4. Chevrolet : Silverado 1500 1500 LT3 Silverado 1500 Crew-2WD-Show Truck
    By Steve in forum Chevy Trucks For Sale eBay
    Last Post: 08-15-2009, 05:11 AM
  5. Chevrolet : Silverado 1500 1500 LT3 Silverado 1500 Crew-2WD-Show Truck
    Last Post: 08-01-2009, 02:50 AM
