I recently got a 97 Tahoe 4x4 with 15x10 bullet hole wheels on 33" 12.5 tires. The truck has a 2" body lift. How will the Tahoe sit with the 22" compared to the 15" on 33 tires. Looks to me like the 22" wheels look about the same height as the 33 tires I have now. I will not get my 22" until next weekend so i was wondering if it would sit about the same height with my new wheels. What effect would the 22" have on the gas mileage compared the the 33" tires. What the differnce in ride quality will be? Thanks
305's are 32.7" i believe. The ride will be a lot rougher, as there is less rubber to cushion the ride. Just a heads up. If the 33" tires are mudding tires, and the 305's are street tires, You should technically get better mileage with the 305's.
2002 Chevrolet Silverado 1500 z71
6.5" BDS Suspension Lift Key'd to 9"
5.5" Lift Springs with 4" Blocks
35" Toyo Open Country Mud Terrain on 18" Ion Alloy 179's
AirAid Cold Air Intake with K&N Dry Filter & AirAid PowerAid Throttle Body Spacer
Pacesetter Long Tube Headers with Catalytic Converters Removed and True Dual Exhaust FlowPro Mufflers 4" Stainless Tips
Bosch +4 Iridium Spark Plugs MSD Ignition Plug Wires
Innovate LC-1 Wideband o2 Sensor x2
BDS Dual Steering Stabilizers
Electric Fan
4.56 Gears
EFI Live
if you are going to do any off roading stick with the 33's on smaller wheels, but if you like the 22s and its a city dweller (mall crawler) then go with the 22's and 305's.
David
2004 Silverado 2500 Crew Cab 4x4, Airraid cold air intake, Throttle body spacer, Magnaflow exhaust (true dual to 2 in 1 out muffler), 6" ProComp lift (add a leaf and 5" superlift rear block), Bilstein shocks, 35's (Cooper Disoverer ST's) and 4.10 gears, Rhino Liner, fiberglass tonneau cover, extended stainless steel brake lines, firestone airbags.
1960 Land Rover Series II 88
2002 Nissan Altima (wife's Car)
1999 Saturn SC1 (the new commuter car)
Nope, no off roading. My wife drives this more than me.
anything over a 20" wheel w/ less than a 35" tire will look out of proportion imo.
Bookmarks
