Results 11 to 16 of 16
    Jr. Engineer
    May 2005
    Minnesota
    Honestly though the problem is not solved, I have replaced the plugs, wires, cap, rotor, ignition module, Battery and still intermittantly when I some to an intersection or more generally remove my foot from the accelorator the truck partially stalls. One of the shops that looked at it said that at the point is stalls the alternator meter dips and the timimg drops from 17 degrees to 2 degrees. On a couple of occasions the truck has actually stalled completely. My only other thought on this is the fuel pump.....
    Anybody else have an idea?
    Nice new GMC!!
    The only other thought that comes to mind on your 95 is possibly the torque converter clutch is not releasing immediately when you come to a stop. I'm not sure if that would set a code on the obdI systems (which the 95 is) but it does on the obdII systems.
    Gary
    99 K 1500 Suburban
    00 S-10 Blazer
    1976 Trans Am
    1980 Honda CB900 Custom
    Jr. Engineer
    May 2005
    Minnesota
    I will have to look into that one. Has anybody had any experience with the throttle postion sensor? How to check it or replace it etc...? A guy here at the office suggested that might also be a culprit for something like this.
    Jr. Engineer
    May 2005
    Minnesota
    another thing somebody mentioned is the IAC (Idle Air Controller).
    Aug 2006
    florida
    if you have an EGR valve on intake it could be getting stuck open from carbon decarb motor an check or change egr valve johnny
    Legend unplugged's Avatar
    Sep 2006
    High Deserts of SoCal
    Ooooh, I love the intermittent or difficult to trace troubles. Especially when they aren't on my truck. lol. Sorry, but my first two stops would be:
    1. Check for vacume leaks
    2. Check the fuel pump pressure.
    To check for a vacume leak I'd remove the air cleaner/inlet assembly off the throttle body, then with the engine at idle I'd start to cover the air inlet on the TBI unit. As you start to 'choke off' the air supply if the engine starts to idle faster, or if a rough idle smooths out I'd suspect a vacume leak. Get a spray bottle filled with water and spray it around the gasket surfaces, like the throttle body gasket, the intake gasket area etc. Spray around the throttle body shaft too. If the idle behaves like it did when you were 'choking' the engine that is the leak source.
    I had a dodge that had stalling stumbling problems that were so intermittent that it drove me almost to drink. I bought a fuel pressure gauge and spliced it into the fuel line. I ran the hoses to the gauge mounted in that area between the hood and wipers. (Don't try running into the passenger compartment. Big fire hazard.) Sure enough whenever the old dodge starting stalling the fuel pressure dropped to the 5-8 psi range which was too low. Replaced the fuel filter and the electric pump that was in the tank and the problem was gone.
    With a jury rigged fuel pressure gauge, you'd get an idea what the fuel pressure was at the time the symptom was occuring.
    Just my first crack at this one. Please keep us informed. Like I said, I really love the tough ones.......
    High Desert SoCal
    02 Honda Civic LX
  1. TPI on a 95 burb ?? [Expired Topic]
    By 2loud in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 09-03-2006, 05:01 PM
  2. how to take dome lights off ? [Expired Topic]
    By sofiah16 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 07-20-2006, 12:45 PM
  3. Trailer lights [Expired Topic]
    By samoraml in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-28-2006, 09:23 PM
  4. Lost dash lights and tail lights???? [Expired Topic]
    By martone68 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-12-2006, 07:02 AM
  5. 1998 Chevy Burb Windshield Wiper motor [Expired Topic]
    By QTee in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 10-09-2005, 08:40 AM
