Results 1 to 4 of 4
    Newbie Earl27 is a glorious beacon of light
    Jun 2009
    Default outside temp on DIC
    I just added the DIC on my 2009 W/T. Can't find the outside temp. Is this sonething that's supposed to be there?? Or should I not expect that function since it's aftermarket.
    Thanks
    Sr. Apprentice VectraGT is a glorious beacon of light
    Jun 2009
    Kaiserslautern, Germany
    The outside temp is displayed on the top right of the screen, but there isn't a special screen to go to. (i.e. you can't select it using the buttons) I know that most of the cables are run on just about every truck. If not, its an easy job.
    JR
    2009 Silverado Z71, 5.3
    Under bottom coating
    Line-X bedliner
    Rhino Cat-back exhaust
    AEM Brute Force CAI
    more to follow
    Jun 2009
    it's not there.................I'm confused about it...................
    Legend 1st Synthetics is a name known to all
    Feb 2009
    Nationwide
    The outside temp wound be on the mirror not the DIC. So if you do not have the electric mirror with a compass you will not have it. As far as I know that is the case.
    2008 GMC Sierra 2500HD Ex. Cab, Fire Red, 6.6L Duramax LMM Equipped with UTG Rocker Pods
    AMSOIL is the only oil company that...,"Recommends 25,000 mile oil changes","Gives up to four times better wear protection","Warranties your engine against oil related failure"
    Preferred Customers Save up to 30% Click here!!!
    Executive Direct Jobber ZO# 1695636
    Scott Douglass 248-721-1002
    Order online:
    www.1st-synthetics.com
Similar Threads
  1. Temp???
    By TJ smith in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-24-2011, 10:12 AM
  2. Temp Gauge on a 94 GMC
    By 94 Jimmy P/U in forum Powertrain
    Last Post: 08-17-2010, 04:25 PM
  3. what temp?
    By warsey in forum Chevy Blazer Forum (GMC Jimmy)
    Last Post: 06-23-2009, 08:59 PM
  4. Temp
    Last Post: 05-13-2009, 04:02 PM
  5. Low temp gauge [Expired Topic]
    By BigWhite2500 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 09-16-2006, 09:47 AM
