Hey I'm new here and have been researching torsion bars.
My 03 Burb 4x4 is riding low in the front and it appears the be excessively riding on the bump stops on the lower control arm.
My symptons include, rough ride (I thought it was the shocks), and the front end is almost 2" lower than the rear.
Do torsion bars "wear out" and allow the front end to come down some? And if so, can cranking them bring it back a little. I don't seem to have many turns left on the bar and I haven't tried that yet.
If the bars are indeed fatigued and need replacing, where and how much? I see they are $200 each from GM.
Thanks for any help and it looks like a cool forum.
Duke
Under normal circumstances they should not wear out on an '03. They can break though. If you want to save money go to a yard and get used ones. Failures are rare but do happen.
Has it ever had a plow on it? I have seen trucks with blades on them put extreme stress on the bars and prematurely wear them out. It's a rare thing but you could of gotten some crappy ones right from the factory. Junk yard parts are ok, but that will be 2 sets of bars you have to fight to get out and then put 1 back in. At least with new ones you'll know that they haven't been over stressed.
1997 Chevy K3500
4x4 X-Cab Dually
454 Dual Exhaust
No plows or extreme towing, just a small pop-up camper. I guess the first thing I should try is giving it a few turns to see how much it comes up.
2008 GMC Sierra 2500HD Ex. Cab, Fire Red, 6.6L Duramax LMM Equipped with UTG Rocker Pods
AMSOIL is the only oil company that...,"Recommends 25,000 mile oil changes","Gives up to four times better wear protection","Warranties your engine against oil related failure"
Preferred Customers Save up to 30% Click here!!!
Executive Direct Jobber ZO# 1695636
Scott Douglass 248-721-1002
Order online: www.1st-synthetics.com
Additional question....
Should the lower control arm be resting on the bump stops or should there be a gap between the bump stops and LCA?
More info: The front is about 1.5" lower than the rear and the left front bump stop is compressed while the right one is touching.
They shouldn't be touching. Also after turning it up watch your tires for uneven wear, you destroy a set of tires in no time with your bars cranked up.
1997 Chevy K3500
4x4 X-Cab Dually
454 Dual Exhaust
1 turn of the torsion key bolt should get you 1/4" of lift if i'm correct. i cranked mine all the way up and i definatly need an alignment. my tires are wearing uneven.
2006 Silverado Z71 - 97,000 - totaled, RIP
2006 Silverado Z71 - 70,000 (K&N 77 Series CAI, PowerAid TBS, Magnaflow dual rear exit, 33x12.50 Mickey Thompson MTZ, Tuff Country Torsion Keys, Tuff Country Add-A-Leafs)
I'll keep my money, guns, and freedom. You keep the Change.
OK, I turned the left one 4 turns and it raised about 3/4" and I turned the right one 2 turns and it came up about 3/8' to equal them out. Additionally, the bump stop has clearance on the right side and almost on the driver's side. In summary, the ride imporved because I got the lower control arm off the bump stops. I'm happy and probably out of turns on the driver's side. The next step would be to get new torsion bars.
Sounds like your on the right track to getting it squared away. Good luck
1997 Chevy K3500
4x4 X-Cab Dually
454 Dual Exhaust
Bookmarks
