Results 1 to 4 of 4
Thread: AC problems
    Jr. Apprentice stagutters is a glorious beacon of light
    May 2009
    Default AC problems
    I have an 05 2500 HD I have the digital temp read out with the "auto" setting there is a separate temp dial on each side to control the temperature for driver/passenger separately (picture probably would have been easier) anyways the when I try to turn on the AC the display reads 60 degrees with the little snow flake icon but the air coming out is 90 degrees plus! the first time it happened I was able to shut the truck off and when I started it, the ac worked again. today I tried the same thing and the ac came on for a second and then switched to hot air. I'm sure there is a switch or temp gauge broken. has anyone else encountered this and how do I fix it?
    Legend unplugged has a reputation beyond repute
    Sep 2006
    High Deserts of SoCal
    Sounds like you have something more serious. I'd get the pressure checked to make sure you have enough freon. There is a high and low pressure cutoff switch that may be turning the air off.
    There is no way to happiness....happiness is the way.
    http://kx6ijq.blu.livefilestore.com/y1pcOFVNH4ix1hjyGUVyXK5LRfef7qSeWzlZDorpQhIEfkZ2ZA  _vXMYypuKMJFw671uF2ZPhjez_j-atRmcjM2zQKpQi1JSsB75/burb1.JPG
    High Desert SoCal
    93 K1500 burb (personal) 350 AT 3" Lift 250K+
    02 Honda Civic LX
    Looking for a 1990's Miata for an engine swap
    Sr. Mechanic bill190 is a glorious beacon of light
    Jul 2009
    Oregon
    Things to try first...
    Reread the owner's manual "climate control section" to be sure all the controls are set as they should be.
    Next try "recalibrating the system"...
    Turn the ignition off.
    Remove the HVAC/ECAS fuse for 30 seconds, then replace it.
    Start your vehicle.
    Do not touch any buttons or switches for 1 minute. (A/C will recalibrate itself.)
    If that does not work, then you would need a GM Factory Service Manual set for your year/model vehicle. This would give complete troubleshooting instructions for this problem as well as complete part replacement instructions. Order this from helminc.com or a GM dealer.
    Or take your vehicle to a GM dealer for service.
    92 GMC Sierra 2500
    May 2009
    Thanks,
    Ill try it out! It seems to be working propoerly again (just stuck on heat for 2 days) so I'm not sure what to think. We'll see how it goes.
Similar Threads
  1. S10 ZR2 4x4 problems
    By footballmn in forum Powertrain
    Last Post: 01-21-2010, 09:35 AM
  2. 4wd problems
    By NewfZ71 in forum Powertrain
    Last Post: 01-11-2010, 11:35 AM
  3. 4wd problems.
    By 95Chevyk1500 in forum Powertrain
    Last Post: 12-10-2009, 02:05 PM
  4. Chevy Silverado Heater problems blower problems
    By bidutch in forum Powertrain
    Last Post: 12-13-2007, 06:59 PM
  5. Got a few problems
    By 95chevyguy in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-16-2007, 01:03 PM
